BX Cable And Tin Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 10:53 AM   #1
BX Cable and tin ceiling
Is it OK to run bx cable atop a tin ceiling, i.e. is there a shock or short hazard? The cable runs along the bottom of the joists and there will be furring strips between the joists and the tin, but i would suspect that the cable will make contact with the tin somewhere.
brookny is offline   Reply With Quote
Old 09-18-2011, 11:00 AM   #2
Code05's Avatar
Rewards Points: 1,104
As long as the BX is bonded it is legal. I do not really like the idea.
Code05 is offline   Reply With Quote
Old 09-18-2011, 11:14 AM   #3
It is new AC 12/3 cable, so it has the bonding strip, and is terminated on each end of the cable with clamps at the j-boxes...is that what you mean?
Old 09-18-2011, 11:16 AM   #4
Code05's Avatar
Yes. As long the first box is bonded correctly you are fine.
The Following User Says Thank You to Code05 For This Useful Post:
brookny (09-18-2011)
Old 09-18-2011, 11:31 AM   #5
Code05's Avatar
If this wire is not being fished in an existing cavity, you need to follow some other rules.
The cable must be installed at least 1 1/4" inches from the face of any stud or furring strip.
Any holes holes must be drilled so are still meeting this requirement. If the hole results that cable is too close to the face, you must use nail plates to protect the cable.
