Buzzing In My Panel. UGH!!!!! - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 03:17 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Buzzing in my panel. UGH!!!!!
I noticed it just a few minutes ago when I was walking around out there. Not sure why I haven't noticed it before, maybe because the water heater is on a timer.
I listened carefully and it seemed to be coming from behind the breakers in the panel, so I shut breakers off until it went away, and narrowed it down to the water heater upstairs. When I shut the breaker off it goes away. Turn it on and it comes back. If I shut off the timer, it stops buzzing. (no, it's not the sound of the timer that i'm hearing, these are two separate sounds)
I pulled the breakers out and looked at them, and they look ok. I snapped them back in and made sure they were seated well. Screws are tight.
Could the breaker just be bad?
Journeyman Plumber
Old 02-05-2012, 03:24 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I have had breakers do that before and just replacing them worked. But I checked all the connections on the circuit first.
rrolleston is offline   Reply With Quote
Old 02-05-2012, 03:31 PM   #3
Master Electrician
Rewards Points: 3,772
What size is the breaker(2 pole?), the conductors, and the W.H.?
brric is online now   Reply With Quote
Old 02-05-2012, 03:50 PM   #4
Doing it myself
Alan's Avatar
2 pole 30A, and wire looks like 10 gauge to me (definitely not 12)
water heater is a standard 50 gal electric.
Journeyman Plumber
Old 02-05-2012, 03:55 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Do you have access to an amp meter?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-05-2012, 04:02 PM   #6
Doing it myself
Alan's Avatar
Not today I don't. We have a couple at work (nobody there knows how to use them apparently, so they just collect dust)
Journeyman Plumber
Old 02-05-2012, 04:04 PM   #7
plummen's Avatar
Now thats funny!
If you can get a clamp on version from work clamp it around 1 power leg at a time and see what the heater is drawing before condeming the breaker
Old 02-05-2012, 04:13 PM   #8
" Euro " electrician
frenchelectrican's Avatar
That is the most common tool device I used alot and they are not super hard to use once you understand how to use it.
Anyway for common 4500 watt water heaters element will draw at 18.75 amp or so. it will be little varation from the number I stated due depending on the supply voltage.
Just keep in your mind if you have 5500 watt element it will draw 22.19 amps again that will varies a little depending on voltage.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
plummen (02-05-2012)
Old 02-05-2012, 05:18 PM   #9
Doing it myself
Alan's Avatar
How much would I have to spend to get a decent one for myself? Sounds like it might be handy to have around anyway.
Journeyman Plumber
Old 02-05-2012, 06:28 PM   #10
Alan.,
The cost of the clamp on ampmeter will varies a bit and depending on how fancy you want to go and the basic clamp on ampmeter will go over 40 Euros and up.
I have 4 differnt ampmeters with me but for the most everyday useage I use Fluke T5 that have open end and very easy to use and hard to get that screw up at all that run about 80 to 100 Euros depending on where you get it from.
Merci,
Marc
Old 02-05-2012, 09:07 PM   #11
plummen's Avatar
I think i gave around $150.00 for my UEI meter but ive had it for atleast 6-7 years I bet without any trouble
Old 02-05-2012, 09:16 PM   #12
Some samples of prices from Nextag
110
54
60
85
81
126
199
69
163
77
97
205
From this, Excel says half the time you'll spend between $75 and $135.
Old 02-05-2012, 09:42 PM   #13
Licensed electrician
Rewards Points: 1,288
Do you have another 30 amp 2 pole in the panel that you could switch with the WH breaker? This might give you an idea if it is the breaker or another problem.
No spreadsheets were used in the formulation of this answer and is based on experience only.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
a_lost_shadow (02-06-2012), Mikenra (02-06-2012), plummen (02-05-2012)
Old 02-05-2012, 10:47 PM   #14
Doing it myself
Alan's Avatar
Actually, I misposted earlier. It is actually two 30 amp single pole breakers tied together with a little metal rod. . . . terminology for that part escapes me. Not sure if this makes any difference or not.
At any rate, i'm not opposed to spending what amounts to probably 15 or 20 bucks on a new breaker to see if that fixes the problem if it's a possibility. I guess that would be cheaper than buying an ammeter. That is if I can't borrow one of the ones from work tomorrow.
Journeyman Plumber
Old 02-05-2012, 10:51 PM   #15
That part is called a handle tie.
frenchelectrican (02-06-2012)
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 06:27 PM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Panel cleanup gdoucette Electrical 5 06-26-2010 03:01 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
