Buzzing Dimmers And Recessed Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2012, 04:44 PM   #1
Rewards Points: 27
Buzzing dimmers and recessed lights
My home office has 6 can lights on 2 dimmer switches. The round ones seen here:
If the knobs aren't dialed into the perfect positions, they buzz, as do the bulbs. And most of the time, one or the other is always buzzing. It's driving me nuts.
I keep the lights as bright as possible, so there's really no need for the dimmers. I was thinking about replacing the dimmer switches with regular light switches. Will this solve the buzzing problem in the switches and in the cans?
mikemcd is offline   Reply With Quote
Old 01-27-2012, 04:52 PM   #2
Yes.
What kind of lamps(bulbs) are you using?
If they are CFL you need dimmable CFL's and a dimmer compatible with CFL.
Those dimmers look older and won't work with CFL's
Good luck,
Bluehawks is offline   Reply With Quote
Old 01-27-2012, 05:04 PM   #3
Rewards Points: 27
I think they're regular CLFs (non dimmable). Which probably explains the buzzing there. The switches do look old. I'm still inclined to just swap out the dimmer switches for regular switches.
Old 01-27-2012, 05:11 PM   #4
That is all you need to do to make the buzzing stop.
Old 01-27-2012, 06:01 PM   #5
Licensed electrician
Rewards Points: 1,242
Try another brand of bulb or use a rough service or 130 volt rated bulb. The buzz is the filament vibrating.
Old 01-27-2012, 06:11 PM   #6
Rewards Points: 27
Originally Posted by Jim Port View Post
...The buzz is the filament vibrating.
What about at the wall? I'm hearing a buzz from the switches, too.
Old 01-27-2012, 07:29 PM   #7
Rewards Points: 240
Cheap dimmers.
fa_f3_20 is offline   Reply With Quote
Need Help Adding Switches and New Lights JCWarrior Electrical 6 11-16-2011 06:45 PM
Recessed lighting design questions secutanudu Electrical 9 07-05-2011 02:00 PM
Help with Lutron Maestro IR dimmers jkr77 Electrical 5 02-28-2011 09:38 AM
Recessed lights: CFL vs LED opinions badgervet Electrical 12 06-19-2010 07:08 PM
Recessed lighting & ceiling fan installation advice SillySally Electrical 5 08-05-2009 11:07 PM
