Buzzing Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 10-09-2011, 10:06 PM   #1
Rewards Points: 43
I heard a buzz coming from my breaker box. When I pressed on each breaker, one by one, the buzzing stopped when I pressed on one of them.
A few weeks later, the same thing happened, and again when I pressed on that same breaker the buzzing stopped. Is there any danger here? Does that breaker need to be replaced?
Jazan is offline   Reply With Quote
Old 10-09-2011, 10:30 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
If the buzzing stops when you press on the breaker, and the load is constant, it likely means a loose connection to the panel buss. Loose buss and wire connections cause heat and arcing which have the potential to start a fire. Sometimes the breaker's connection gets loose over time through either improper torqueing or constant heat cycling. More commonly it sees to happen on higher amperage drawing circuits.
Without knowing what kind of panel and what is on the circuit, its harder to make a recommendation. You can certainly replace the breaker if you feel comfortable doing so, however if the breaker's connection to the buss bar is compromised you may not be able to get a good connection and further work may be necessary.
iminaquagmire is offline   Reply With Quote
Old 10-10-2011, 07:32 AM   #3
Rewards Points: 43
Buzzing Breaker
Thank you for your prompt reply. The breaker box is a GE Class CTL,
and the breaker is a 15A regular (not a GFCI) one. I will replace it
with a new one ASAP as you have suggested. Thanks again.
Tags
buzzing , circuit breaker
Have 120 volts with circuit breaker off justforjacks Electrical 2 07-03-2011 12:14 PM
Circuit Breaker restlessnlr Electrical 2 05-08-2011 01:12 PM
circuit breaker? blueandyellow Electrical 7 01-30-2011 11:27 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 07:06 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
