Buy A Hole Cutting For Recessed Lighting Install? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-22-2009, 04:32 PM   #16
Rewards Points: 278
I am interested in the X-200 But I didn't know the addition of the shield suddenly added $70 over the no shield model.
DIYGST is offline   Reply With Quote
Old 01-22-2009, 07:14 PM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by DIYGST View Post
BTW I looked at the green Lee cutter too one review from Amazon say it's not good at all and ended up using a saw.
Probably didn't read the instructions
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-23-2009, 04:49 AM   #18
Electrical Contractor
kbsparky's Avatar
Want to minimize dust? ....
Then use a Roto-ZIP with a vacuum attachment. Be sure to use a decent shop-vac and you won't have hardly any cleanup.
Be warned however. You still need to use a drop-cloth under your work area, as the slug from the ceiling will fall free once you cut thru the entire circle. There will be some dust from that, but way less than open cutting would produce.
Old 01-23-2009, 05:08 AM   #19
the Musigician
DangerMouse's Avatar
unless you screw a drywall screw into it to give you a 'handle' on it. =o)
DM
Old 01-23-2009, 12:56 PM   #20
220/221 is offline   Reply With Quote
Old 01-23-2009, 01:35 PM   #21
UAW SKILLED TRADES
Stubbie's Avatar
Originally Posted by 220/221 View Post
What's that thing....looks like something my doctor uses during my yearly physical...
If I'm dealing with drywall I prefer a circle cutter designed for recessed cans.... but a drywall saw always works in a pinch....
Stubbie
Old 01-23-2009, 02:16 PM   #22
Remodeling Contractor
By the time he reads all these suggestions he could have cut enough holes to wire the whole house and cleaned up the mess.
Old 01-23-2009, 02:24 PM   #23
I've used the rot-zip & the hold saw depending upon where I'm putting the light. I bought 6" cans for my great room. The 4" cans were like $20-30 each with trim. A 6 pak of 6" cans with everything was $45
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 07:56 AM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
I need to install motion lighting. Floorwizard Electrical 4 10-21-2006 07:05 PM
Cutting brick to install windows (lentals?) buckwillis Building & Construction 6 08-21-2006 08:13 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 10:16 AM
