Butyl Caulk Alright On Wire Insulation? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2011, 11:52 AM   #1
Mike K
Rewards Points: 83
Butyl caulk alright on wire insulation?
I'm sealing all the wire holes in my attic before re-insulating. I would like to use up all my left over tubes of caulk before buying new. I figure silicone and acrylic caulks are fine for this purpose and wont soften or deteriorate the wire insulation. But Just wondering if Butyl caulks are alright and wont break down the plastic insulation on the wires.
Anyone?
Thanks before hand
rebar is offline   Reply With Quote
Old 10-05-2011, 12:13 PM   #2
Rewards Points: 760
Is this getting inspected? You may need to use an "approved" fire rated caulking to seal the holes.
There shouldn't be any problems with the cables coming in contact with any ordinary sealant used in a household.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
frenchelectrican (10-05-2011)
Old 10-05-2011, 12:21 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Most place I know when they are getting strict with it espcally with inspectors they will useally required approved fire rated chalking that useally in red in colour.
For plain jane sealent some willbe ok and some are not all depending on what type it is.
Merci,
Marc
Old 10-05-2011, 04:34 PM   #4
Mike K
Rewards Points: 83
No Inspection. I'm the home owner who removed cellulose, and will install R49 blown fiberglass.
This is the stuff I have allot of.
http://www.tbpconverting.com/product...mer-511-us.pdf
Its for metal roofs and sika told me its never been tested with electrical wiring.
Originally Posted by frenchelectrican View Post
For plain jane sealent some will be ok and some are not all depending on what type it is.
Merci,
Marc
Which type isnt OK with wiring?
Old 10-05-2011, 04:44 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
use foam,save the caulk for the metal roof like its made for
Tom Struble is offline   Reply With Quote
Old 10-05-2011, 05:00 PM   #6
the Musigician
DangerMouse's Avatar
....or just go buy some fire caulking and do it right and then you won't have to worry if it'll hurt the wires or not!
DM
Old 10-05-2011, 06:12 PM   #7
Mike K
Rewards Points: 83
DM
Good plan.. The heat in the attic must have been getting to me when I considered being cheap.
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 03:15 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 04:24 PM
Is it alright for insulation to touch a heating duct? vetting Building & Construction 5 02-28-2009 02:46 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
