Butt Joint Connection - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 06:36 PM   #1
Hi all,
I'm moving an electrical outlet using wire molding and a surface mount outlet box. Well, this is my intention anyway.
I removed the old outlet box and surface molding and was left with two black wires coming out of the wall.
Now I have to connect new wire to these old wires and run that up the molding to the box.
So my question is, is it best to solder this connection? Or will this product work?
Thanks.
scott490 is offline   Reply With Quote
Old 02-04-2013, 07:13 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You will have to add a junction box to extend that circuit. And you will have to use wire nuts.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-04-2013, 07:26 PM   #3
MarginallyQualified
Rewards Points: 2,464
Is this a 240V circuit?
Where is the neutral? The ground?
No.
Once you re-establish the entire circuit (find the missing wires)
then (as rrolleston said) terminate them in a junction box and go from there.
Old 02-04-2013, 07:36 PM   #4
Oso954's Avatar
Rewards Points: 442
I'd also question the wire size. It should be #14, yet the picture of the butt connectors is #16-22.
Oso954 is online now   Reply With Quote
Old 02-04-2013, 08:02 PM   #5
Not a 240.
No ground apparently. Just the two wires as shown. The old outlet didn't have anything connected to the ground screw.
Old 02-04-2013, 08:07 PM   #6
MarginallyQualified
Not a 240. No ground apparently. Just the two wires as shown.
Dig deeper. Find where those wires come from.
If THAT connection doesn't have an identified neutral (white)...
then dig deeper still until you find where those wires come from.
Old 02-04-2013, 08:55 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,860
Something's real bad wrong here, as they say. This was clearly not installed by a competent person. You're going to have to remove it back to wherever the properly-done wiring is, and redo it form there.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 02-04-2013, 09:06 PM   #8
Thanks for the responses. Unfortunately getting to the bottom of this would be tough or very expensive. This is a 1920s apartment bldg and the wiring is behind tons of plaster. If I do as some have said and route this thru a junction box would that not be an answer and at least be safer than the old setup?
Old 02-04-2013, 09:12 PM   #9
MarginallyQualified
If the power went out to this would you know where the fuse or breaker is?
If so... then half the job is done. If not... then leave it alone.
If I do as some have said and route this thru a junction box...
You'll need to do this no matter what else you do.
Install a box in that corner, wirenut the ends and close it up.
The question is whether you can (safely) reinstall an outlet in that box...
or add additional wire, wiremold and other boxes/outlets as you planned.
Old 02-05-2013, 06:55 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
You are not allowed to extend an ungrounded circuit. You should not being doing work in a rental unit.
Coastal South Carolina
Old 02-05-2013, 08:22 AM   #11
rrolleston's Avatar
Zooming in on the picture looks like the two wires just come out of the wall and they are stranded. I would find out where they come from. I would not extent them to add more receptacles.
Old 02-05-2013, 10:14 AM   #12
So I guess what I'm hearing is that those 2 wires fed an illegal, code violating outlet for decades and should not be reused.
The Following User Says Thank You to scott490 For This Useful Post:
mpoulton (02-05-2013)
Old 02-05-2013, 11:26 AM   #13
Yes there is a circuit breaker which controls this outlet as well as 2 others in the apartment.
Old 02-05-2013, 01:05 PM   #14
Yep. That's about right.
Old 02-05-2013, 03:20 PM   #15
MarginallyQualified
Then (as mentioned above) you should/may be able to trace back along this
circuit until you find an appropriate source of power to feed your room and how to route the NEW cable needed to replace the existing wire.
If you have to go back to the panel... so be it.
If you can't do the above you're back to (safely) abandoning the existing wire in place.
Butt end to tapered end? Oxymoron Drywall & Plaster 20 06-04-2016 03:21 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
How to rotate this t joint on drain? hobbs in vanvouver Plumbing 9 02-16-2010 10:55 PM
Cracked drywall at joint near door? ClemsonJeeper Drywall & Plaster 6 11-06-2009 04:27 PM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 07:10 AM
