Burying Utility Lines - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 10:45 PM   #1
burying utility lines
Can I bury an electrical line and a water line in the same trench?
Glen n Ca. is offline   Reply With Quote
Old 09-20-2011, 10:59 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,638
It depends on what your utility says. Most people place them horizontal from each other, in a trench aprox 4 feet wide, so that you do not have to move one out of the way for the other, if repairs ever have to be done.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
Code05 (09-20-2011), frenchelectrican (09-21-2011)
Old 09-21-2011, 12:29 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Not always the case depending on the water dept and POCO requirment for burial uilitys stuff plus phone or cable and gaz as well.
Normally I know both water and sewer genrally buried more deeper than any other uilitys stuff is { I know not always the case depending on location }
I know in Wisconsin the water line are at min of 4 feet deep most useally run 6 or more feet down for sewer it will varies a bit but typically almost same plane { level } as water line is.
Gaz typically 24 or 36 inch down for latheral run but main run that will varies a bit but useally 4 to 6 feet down.
Ditto with Electrique system useally more than 2 feet down { most case latheral useally at 3 or 4 feet down }
France is not much differnce on the depth as well central and north France is about the same as I mention about Wisconsin but southern France simaur to southern states on depth wise. { again it depending on uilites requirement }
Merci,
Marc
Low point in water supply lines dave11 Plumbing 3 02-01-2011 07:13 PM
My utility room's wiring, before rewiring WillK Electrical 0 01-07-2011 10:44 PM
slow hot water lines sobro Plumbing 3 11-05-2010 10:44 AM
burying lines, granite below surface nppx Electrical 4 08-21-2010 03:18 PM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 05:02 AM
