Burying Power Line - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 01:22 AM   #1
Unhappy
Burying Power Line
Please help. I have no electrical knowledge. I have gotten a bid for an electrician to burying the line that drapes into my small backyard. The bid says he will use "4/0 aluminum wires. For a 200 amp service." Help. What is 4/0? Do I want aluminum wires? Do I want copper wires? If this is for a 200 amp service and someday I remodel making a need for additional breakers/service, then will I have to dig and add more wire? Many, many thanks to all that can educate me! LK, Houston.
txlulu is offline   Reply With Quote
Old 07-13-2012, 01:29 AM   #2
So you have a 200Amp service now? or your upgrading to a 200Amp service. I'm not an electrician, but I'm pretty sure the wires coming into your panel from the street are almost always aluminum. The 4/0 just is the thickness of the wire, 4 gauge.
CopperClad is offline   Reply With Quote
Old 07-13-2012, 02:11 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,922
Aluminum is much cheaper, with no difference in functionality for this purpose. If you need to upgrade the service to more than 200A in the future, you would have to replace the cable. For more than a 200A service, parallel conductors are likely to be required, and possibly multiple conduits. If you think you'll need to upgrade in the future then it would be wise to install two 3" conduits now since most of the expense is trenching.
mpoulton is offline   Reply With Quote
Old 07-13-2012, 12:04 PM   #4
Yes, my current service is 200 with no open breakers. Thank you for your post and advice.
Old 07-13-2012, 12:06 PM   #5
Thanks! This is great information. I appreciate your post.
Old 07-13-2012, 12:18 PM   #6
MarginallyQualified
Rewards Points: 2,464
Aluminum is fine.
What does the power company say?
Around here Duke would do it.
Tags
aluminum , bury , copper , size , wire
How does grounding work? scyarch Electrical 44 06-12-2012 04:59 PM
new underground power and new water line David P Building & Construction 3 05-31-2012 09:24 AM
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 10:51 AM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
moving incoming power line and grounding rod amakarevic Electrical 3 07-28-2008 11:24 PM
