Burying Conduit - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-31-2013, 11:34 AM   #31
Maryland
Originally Posted by k_buz
All the prebent 90's I have used have had a short straight section on each end so you don't have that problem. Did you cut the end of the 90 off?
No, I didn't. It was a 36" radius sweep, so basically the whole thing was a curve. Because of the bell depth, the curve started entering the bell and left a gap on the bottom. I suspect that the sweep made contact somewhere along the bell, but I think I'm going to use couplers going forward to avoid the issue.
Pittsville is offline   Reply With Quote
Old 08-31-2013, 11:36 AM   #32
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Couplings will make no difference. If the entire piece of conduit is bent, you will have the same problem.
Old 08-31-2013, 11:42 AM   #33
Maryland
It's not as pronounced. The coupling only allows the sweep to enter about 1.5". The bell on a length of conduit is easily double that distance.
Old 08-31-2013, 12:38 PM   #34
k_buz's Avatar
Isn't going to matter, either way, the same amount of the sweep is going to be in contact with the coupling as the bell end.
Old 08-31-2013, 03:07 PM   #35
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I just load up both ends and jam them together never worried about there being a gap. We are electricians not plumbers.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 08-31-2013, 10:20 PM   #36
kbsparky's Avatar
Originally Posted by Pittsville View Post
So you use regular couplers? Regardless of sweep size?
most of the time, yes.
-KB
Old 09-26-2013, 12:04 PM   #37
Maryland
Just a followup. We finished burying the conduit and built a pedestal. The electrician installed the meter socket and disconnect and it was inspected/passed on Monday. I do have a question about the installation though...
I've attached two photos: one showing the entire install and one showing a closeup of the meter box. The knockouts on the meter box and the disconnect do not line up perfectly, so the piece of conduit between them is slightly angled. Because of this, the remaining knockout rings in the meter box were pulled out, opening a gap to the inside of the box. During our last rain, a good amount of water got inside the box. It was like this when the inspector passed it, but I see this causing issues down the road with corrosion. Is this type of thing common or is this just sloppy workmanship? How concerned should I be about the water making it's way into the box?
Old 09-26-2013, 03:09 PM   #38
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
An offset should have been used or the disconnect shimmed out to the meter socket.
Why was the panel set in front of a window??
Coastal South Carolina
Old 09-26-2013, 03:32 PM   #39
Maryland
The window is going away.
Using an offset makes sense. Should I have the electrician redo this? I assume he'd have to install a new meter box... or knock out more rings and use larger conduit on the existing box.
Old 09-26-2013, 03:59 PM   #40
A "Handy Husband"
rjniles's Avatar
There a repair washers (bushings) that can be used.
Old 09-26-2013, 04:18 PM   #41
Oso954's Avatar
Rewards Points: 1,654
There are minimum glazing and ventilation standards that apply. Hope you are up to speed on those for your area.
Oso954 is online now   Reply With Quote
Old 09-26-2013, 04:35 PM   #42
Maryland
That portion of the home is being demo'd and rebuilt with the window in a different position.
Old 09-26-2013, 04:36 PM   #43
Maryland
I'll ask about these. Thanks!
Old 09-26-2013, 08:56 PM   #44
kbsparky's Avatar
Why did you use separate boxes? DP&L approved the Homeline RC816F200CH, available and in stock at United Electric, or by online order at the Home Depot:
-KB
Old 09-26-2013, 09:48 PM   #45
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I dont see it as being damaged, as the rings are still intact.
Using 2" PVC electrical conduit RonLNY Electrical 7 01-06-2013 10:34 PM
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 08:02 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Help burying conduit. Wanttodoitright Electrical 4 07-19-2008 07:33 AM
