Burying Conduit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-25-2013, 04:50 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,866
Shouldn't be. As long as it stays together.
I might have used a bit more glue on that joint.
Old 08-25-2013, 08:54 PM   #17
Its amazing all the things I learn in this forum ,, keep up the good work guys
RAUL HIDALGO is offline   Reply With Quote
Old 08-26-2013, 02:19 PM   #18
Maryland
I actually had quite a bit of cement on the elbow and inside the bell. I think the large radius of the elbow combined with the depth of the bell contributed to the gap. (A curved piece mating with a straight piece) I suspect that the end of the elbow made full contact somewhere inside the bell.
Pittsville is offline   Reply With Quote
Old 08-26-2013, 04:48 PM   #19
Semi-Pro Electro-Geek
Rewards Points: 2,892
Some inspectors here insist on seeing excess squeezed out of the joint - that way it is visually confirmed that it's fully glued. I'm not sure that's an enforceable requirement, but it is good practice. It's impossible to use too much.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 08-26-2013, 05:07 PM   #20
Maryland
I put a light coat in the bell and two fairly liberal coats on the pipe/elbows. Think I'll be alright or should I relay some new pipe?
Old 08-26-2013, 05:09 PM   #21
Maryland
And the cement did squeeze out, I just wiped off the excess.
Old 08-27-2013, 05:18 PM   #22
Maryland
Whats the opinion on running a second conduit for tv/internet cable in the trench next to the one carrying the power? Interference concerns? Should there be a minimum separation between the two conduits?
Old 08-27-2013, 06:18 PM   #23
Sparky
Rewards Points: 510
if you're really worried about it, put the first 8-10" of fill in then add the LV conduit, but i wouldnt worry.
Techy is offline   Reply With Quote
Old 08-27-2013, 06:36 PM   #24
I agree on both counts.
Old 08-29-2013, 10:56 PM   #25
Maryland
I take it then, that if my long sweep 90s don't make full contact in the bell end of the pipe, that will be ok? See my attached photo. Because of the radius of the 90 and the distance it goes into the bell, it leaves a small gap on the bottom. This wasn't a problem on the other end of the run, because a coupling was used to connect the 90 to the pipe.
Just curious... but you guys HAVE seen this issue in the field, right? Where a large radius sweep leaves a gap in the bell because of the bell depth?
I was talking to an electrician earlier today who stated that he's never seen this problem. He asked about the sweep and when I explained that both ends have spigots, he said I should either be using a sweep with a belled end or making the connection to the conduit with a standard coupler. A gap wouldn't be left that way because the connection wouldn't be as deep as the bell on the conduit? If he's right, whats the point of being sold a sweep with two spigot ends? lol...
Old 08-30-2013, 05:12 AM   #26
Electrical Contractor
kbsparky's Avatar
Where did you obtain such a sweep elbow? None of the ones I have ever bought have bells on the ends ....
-KB
Old 08-30-2013, 11:24 AM   #27
Maryland
That's just it... my sweeps do NOT have bells. So therefore, you either have to insert the end into a coupling or into the bell on the end of a length of conduit, which leaves the gap. The electrician was the one who said I needed sweeps with bells on them.
So when YOU install large radius sweeps, how do you connect it to the straight conduit? If you fit it with the bell of the conduit, have you noticed the gap?
Old 08-31-2013, 05:27 AM   #28
kbsparky's Avatar
Generally, I don't install sweeps into bell ends, for the same reason.
-KB
Old 08-31-2013, 12:13 PM   #29
Maryland
So you use regular couplers? Regardless of sweep size?
Old 08-31-2013, 12:24 PM   #30
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
All the prebent 90's I have used have had a short straight section on each end so you don't have that problem. Did you cut the end of the 90 off?
Using 2" PVC electrical conduit RonLNY Electrical 7 01-06-2013 11:34 PM
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 09:02 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 02:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
Help burying conduit. Wanttodoitright Electrical 4 07-19-2008 08:33 AM
