Bury Low Voltage Wire In Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2008, 08:25 AM   #1
Lost in Space
Bury Low Voltage Wire in Wall?
Hi Guys,
I'm helping a friend of mine install some under cabinet lights in his new kitchen which is currentlky in the rough in phase. Does anyone know if they make a low voltage wire that can be run behind sheetrock? I know the off the shelf wire that comes with the lights cant be used but some one had mentioned that they make an "orange" colored wire that can be buried? I never heard of it but that doesnt mean its not out there?
As always..you guys are the best
Tool Junkie
Tool Junkie is offline   Reply With Quote
Old 06-13-2008, 09:20 AM   #2
Why not just use Romex cable?
NateHanson is offline   Reply With Quote
Old 06-13-2008, 10:54 AM   #3
Rewards Points: 160
I would take a good look at the package instructions. They sell you wire you cannot use? It's low voltage.
Is it allowed for exposed installation? What is the wire rated for.
Old 06-16-2008, 07:38 AM   #4
Lost in Space
I ended up using romex for anything behind the sheet rock. That was the easiest solution and was readilt available. Thanks for your responses.
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Which low voltage wire scozzer Electrical 2 02-18-2007 10:56 PM
