Old 02-12-2009, 08:08 PM   #1
Kyle Emerick
kemerick's Avatar
burnt wire connector...
I have a 6 year old jacuzzi that has worked great up until now. I live in Southern California so it has been wet here recently. The wire connector got fried I assume due to a short making it too hot?
The wire connector is in a mostly aluminum sealed box. The wires are coming from the GFCI box 10 feet away through conduit.
The wires have not been touched in years and the GFCI it is plugged into looks fine including its wires.
My constant project is my home which was built in 1947. I have remodeled almost all of it and am in the process of finishing off a 1000 square foot addition. Lars Construction got me up to drywall and I am doing the rest. You can see many galleries of it
under Galleries and then House.
kemerick is offline   Reply With Quote
Old 02-12-2009, 08:11 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Simply a poor connection that finally failed.
Sucks because that terminal strip should be replaced. I mean as opposed to simply splicing the wire.
Old 02-12-2009, 08:15 PM   #3
Kyle Emerick
kemerick's Avatar
Cool, I will replace the connector. Thanks for your time Petey.
Old 02-12-2009, 08:48 PM   #4
Not a short circuit, simply piss poor design.
Tiny little terminals for big fat wire. I have seen it many, many times. How are you suppose to tighten those things down properly?
This is my biggest peeve. Freaking engineers/designers getting paid real money and they can't even figure out that you need a decent lug on their equipment.
220/221 is offline   Reply With Quote
Old 02-12-2009, 09:49 PM   #5
Electrical Contractor
Isn't that the truth. When you find a screwdriver to fit, you are almost afraid to tighten it down for fear of breaking the screwdriver!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 05:13 PM
replace crimp-on connector with wire nut? Jeremy Hillary Boob, PhD Electrical 13 12-05-2008 02:51 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
