Burning Down The House! - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2010, 08:26 PM   #1
Burning down the house!
My new kitchen cabinets have a recessed bottom. The sides and front extend down 1" farther than the actual bottom, like most. It looks unfinished. So I will veneer the bottom with 1/4" birch. This will give me an enclosed space the length and width of the cabinet 1" deep with no air movement. I really want to recess my xenon light pucks but these suckers get hot! Is it possible? Install with casing on? with casing off? drill 1/8" heat holes? Or just dont do it. I dont want to hear L.E.D. I like the look of xenon. But I also like the look of new cabinets without fire on them. Has anyone done this before? Thanks everyone Nervous
Eri-c is offline   Reply With Quote
Old 04-02-2010, 08:34 PM   #2
check1,2
Old 04-02-2010, 08:59 PM   #3
Rewards Points: 1,016
I used pieces of sheet metal under my xenon under cabinet lights as a heat sink and to disperse the heat - made a huge difference (would not have installed them without some remedation, as they got WAY too hot). I got ready made sheet metal pieces about 6"x8" from the roofing department at Lowes.
Old 04-02-2010, 09:00 PM   #4
Learning by Doing
Leah Frances's Avatar
Eric - electrical thread is good (in fact, it is the BEST!), but expecting a reply in 8 minutes late on a Friday night is asking alot. May I suggest, filling out your location in your profile.
Also, posting some pics helps grab people's attention.
I've never done this, nor do I have any good ideas, except ending your post with a statement that you 'don't want to hear' about LEDs might be turning some people off - seems like you may not want to listen....
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
Eri-c (04-02-2010)
Old 04-02-2010, 09:05 PM   #5
I cant post any pictures right now. time is not of the essence, just checkin the e-mail link. Any advice will be GREATLY appreciated. I apologize for offensive directness.
Old 04-02-2010, 09:12 PM   #6
A HEAT SINK! BRILLIANT! I AM FEELING VERY DUH! Simple dispersion.
Old 04-02-2010, 09:12 PM   #7
Learning by Doing
You weren't offensive, just some friendly advice for getting more advice - and it looks like you're getting some, so here's another bump to keep it active.
Old 04-02-2010, 09:16 PM   #8
VSHEETZ!! Thank you so much..................for not suggesting L.E.D.'s
Old 04-02-2010, 09:20 PM   #9
Newbie Out.
Old 04-02-2010, 10:01 PM   #10
Rewards Points: 152
i was gonna actually install those cabinet lightings later this year.
For the sheet metal, is it just a metal plate under the lights like a base plate, or do i make a housing around the light with the sheet metal?
Also, can i find that at home depot? Lowes is a bit of a mission for me to go to.
humberguy is offline   Reply With Quote
Old 04-03-2010, 12:52 AM   #11
Yes, just a plate between the light and the cabinet. I would imagine HD or any place that sells roofing materials has similar metal flashing.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
