Old 11-01-2010, 01:51 PM   #1
Burned wire coming from circuit breaker
I have a circuit breaker that has recently begun to trip for no apparent reason--master bath lights. I reset it and all seems OK for a few days--then it starts again. This morning it happened again and the breaker would not reset until after 4-5 resets. Same thing happened again a few minutes later. I removed the panel cover to see if there was anything obvious---found that the wire coming out of the breaker was charred--insulation melted. Any idea what the problem is? Bad breaker or some other problem?
rdmirando is offline   Reply With Quote
Old 11-01-2010, 02:10 PM   #2
Licensed electrician
Typical sources of heat damage are loose connections and high current draws on the circuit.
What is in use on that circuit? Was the screw tight on the breaker where the wire connects?
Old 11-01-2010, 02:27 PM   #3
Retired Electrician
Was the CB hot to the touch? Depends on the panel....if it was a Zinsco I would say that it was the CB and Buss bar connection...they are famous for just that.
Lsparky is offline   Reply With Quote
Old 11-01-2010, 03:46 PM   #4
The CB is not hot to the touch. The CB controls MBR lights but not outlets, and the fan light combos in the MBR shower and two other showers. It also feeds a Leviton GFCI motor control and Misc. switch with test and reset buttons that look like GFI buttons. The screw coming from the CB is tight on the wire.
Old 11-01-2010, 06:22 PM   #5
Sounds like some troubleshooting is in order, something is causing the problem...got to find it. If you had an amp meter you could check current draw on that breaker.
COLDIRON is offline   Reply With Quote
Old 11-01-2010, 06:32 PM   #6
Electrical Contractor
kbsparky's Avatar
If the wire connection on the breaker was tight, then the loose connection is inside of the breaker.
Replace that breaker.
-KB
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Red wire on 3 way tripping breaker reinsman Electrical 4 09-14-2010 01:24 AM
Circuit Breaker trips when I plug into an outlet Alex in Orlando Electrical 3 09-05-2010 02:04 AM
mixed gauge wire on 15 amp circuit GretaDIY Electrical 4 07-03-2010 04:20 PM
New circuit breaker owen22 Electrical 14 01-12-2010 08:08 PM
