Old 03-14-2010, 03:32 PM   #1
Buried wire through Septic Field
Is it okay per code to run a buried electrical wire in conduit over a septic field? Is there a specific NEC code number that references this?
Moose50000 is offline   Reply With Quote
Old 03-14-2010, 03:58 PM   #2
Master Electrician
No code issue but doesn't seem to be a good idea. This will be abundanlty clear if you tear up part of your leach field.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Moose50000 (03-14-2010)
Old 03-14-2010, 11:16 PM   #3
You can do it, but whether you should or not would be dependent on the purpose of the wire.
For example, if it was 12/2 wire going out to a fountain, I'd do it.
if it was more than 15-20 amps of service going to something more permanent, I would not do it.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
A hot wire buried in the yard that you cannot even trip a breaker by sharting it? BJLower Electrical 3 01-21-2010 03:24 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
