Buried Service Entry & Water - Electrical - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 11:42 AM   #1
Buried Service Entry & water
I'm changing to a buried service entry which will be 4/0 aln in pvc, but it will need to accommodate the plastic water line as well. I'll put the electric at 18" deep, but I need to know how close I can put my water line to the pvc conduit. I live in Jefferson County, Missouri.
I'll be out for a couple of hours, but I'll stay logged in so I can find my post. It sucks being a newbie!
thanks
Shooty is offline   Reply With Quote
Old 06-06-2012, 02:15 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would contact your inspector and ask what he expects to see.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following 2 Users Say Thank You to rrolleston For This Useful Post:
a_lost_shadow (06-06-2012), Code05 (06-06-2012)
Tags
buried cable , electric code
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
