Old 10-08-2007, 06:01 PM   #1
bundling romex, code?
I don't like the idea of drilling my basement joists like swiss cheese, and I have all my runs going along the perimeter of my basement and upto the walls above (nothing really through the stud/walls themselves).
Can I bundle them all together, maybe like five 12/2's together with zip ties and secure them to the rafter? Or will my inspector have a fit? Otherwise do I have to nail every wire below the joist spaced apart? I don't like this because I want to finish the ceiling someday, and thought I could just bring the walls out 3" to hide the bundles along the perimiter.
seems like a good idea to me, unless any wires ever heated up... which is why they're on a correctly rated breaker, right?
johnnyboy is offline   Reply With Quote
Old 10-08-2007, 06:16 PM   #2
Electrician
Article 334.15 (C) would prevent you from stapling to the bottom of the joist, and 300.15 (B)(2) would limit your bundled cables to 9 current carrying conductors before you would have to start derating your cables...
Personally, just drill out your basement...or install running boards...
chris75 is offline   Reply With Quote
Old 10-08-2007, 06:21 PM   #3
noted. thanks.
Old 10-08-2007, 06:23 PM   #4
Electrician
Originally Posted by johnnyboy View Post
noted. thanks.
I don't agree with bored holes as bundling, some inspectors may, so to be safe you may just want to keep the holes at 3-4 cables each, and I generally use a 1" bit, just make a jig up to mark all your holes you will appreciate the end result...
Old 10-08-2007, 08:11 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Make sure your holes are no closer than 2 inches to the face of the joist and don't make holes bigger than D/3. Other than that I am with the advice given by Chris75.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 10-08-2007, 11:23 PM   #6
Contractor in PA
If you decide to drill out the joist, here is a tip....drill out every other joist going in one direction and then come back drilling the other joist from the opposite direction. The result is something like a wave as opposed to a saw tooth pattern. It will make a big difference on the effort needed during the wire pull.
michaelpwalton1 is offline   Reply With Quote
Old 10-09-2007, 06:57 AM   #7
Electrician
Thats why I said make a jig for marking your holes...
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 11:19 AM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 03:57 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
code question JustJoe Building & Construction 3 01-27-2007 10:06 AM
Pulling romex thru wall with old romex? Doug Crf Electrical 4 04-11-2006 10:33 AM
