Bundling Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2013, 03:14 PM   #1
Rewards Points: 248
bundling romex
I need to bundle romex to get through a tight space in a wall into the panel on the other side. Here is my breakdown:
quantity 6 10/3 cables
quantity 5 10/2 cables
quantity 1 6/3 cable
All this needs to pass through a 2" schedule 80 pvc conduit 6 inches long.
Am I breaking any code? Am I trying to pull too many cables through the 2" hole?
jackwashere is offline   Reply With Quote
Old 09-23-2013, 04:55 PM   #2
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
its 50/50 depending on the inspector the code says ... u get 24" .. to be bundled .... then seperate ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 09-23-2013, 05:17 PM   #3
Licensed electrician
Rewards Points: 1,246
Why the conduit sleeve?
Old 09-23-2013, 05:29 PM   #4
Rewards Points: 6,652
That was my question also. My other is, is this going through a 2x6 plate, or 2x4 plate, or just middle of the floor.
Old 09-23-2013, 05:31 PM   #5
Rewards Points: 516
how about a block wall or stone wall ... ??
Old 09-23-2013, 05:45 PM   #6
Rewards Points: 248
ICF walls
4" of concrete
you put a 2" schedule 80 piece of conduit in the wall before you pour
Old 09-23-2013, 06:41 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Yes, you are breaking code.
The Following User Says Thank You to k_buz For This Useful Post:
gregzoll (09-23-2013)
Old 09-23-2013, 06:46 PM   #8
You are not supposed to tell them that, until the AHJ shows up and Red Tags the whole job, and they come back asking why they cannot do it.
Old 09-23-2013, 07:13 PM   #9
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If the hole isn't fire stopped I say you are good to go....if this PVC actually connects to the panel, total violation....
By the way, I have never pulled so many #10 cables in a house in my entire career, what the heck are you doing?
Old 09-23-2013, 08:51 PM   #10
Rewards Points: 248
I have a separate circuit breaker for each of these:
1 for living room front/foyer
1 for living room back
1 for bedroom
1 for kitchen
1 for bathroom/laundry washer
1 for dishwasher/garbage disposer
1 for refrigerator
1 for outdoor outlet in the back of the house
1 for laundry dryer
1 for water heater in the back of the house
1 for hvac
1 for range
total: 12
I could use #12 for many of these I suppose. The difference is $71 for 250 feet of #12 romex and $137 for 250 feet of #10. I thought having #10 would be better. Am I guilty of overkill?
Old 09-23-2013, 08:54 PM   #11
eastcoastsparky's Avatar
Rewards Points: 150
Originally Posted by jackwashere
I have a separate circuit breaker for each of these: 1 for living room front/foyer 1 for living room back 1 for bedroom 1 for kitchen 1 for bathroom/laundry washer 1 for dishwasher/garbage disposer 1 for refrigerator 1 for outdoor outlet in the back of the house 1 for laundry dryer 1 for water heater in the back of the house 1 for hvac 1 for range total: 12 I could use #12 for many of these I suppose. The difference is $71 for 250 feet of #12 romex and $137 for 250 feet of #10. I thought having #10 would be better. Am I guilty of overkill?
way overkill
eastcoastsparky is offline   Reply With Quote
The Following 2 Users Say Thank You to eastcoastsparky For This Useful Post:
jbfan (09-23-2013), stickboy1375 (09-23-2013)
Old 09-23-2013, 08:54 PM   #12
E2 Electrician
Just a little....but it's your money. Don't forget to weigh in the cost of labor for installing #10, it will offset the cost of installing #12 or #14 big time....
Old 09-23-2013, 09:01 PM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
You might want to consider box fill using all that #10 for receptacles and lighting circuits.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
k_buz (09-23-2013)
Old 09-23-2013, 09:31 PM   #14
k_buz's Avatar
Box fill and the fact that most devices aren't rated for #10's.
Old 09-23-2013, 10:04 PM   #15
Rewards Points: 516
1 for bedroom
1 for kitchen 2 for kitch counter top MIN
1 for bathroom/laundry washer must be 2 seperate circuits
1 for dishwasher/garbage disposer shoulb be 2 different ones
1 for refrigerator
1 for laundry dryer 30 amp if electric 10/3
1 for water heater in the back of the house 30 amp 10/2
1 for hvac most 30 amp 10/2
1 for range 50 amp 6/3
total: 12
blue are 20's
all the rest COULD be 15 amp 14/2
dining room must be 20 amp 12/2
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 01:01 AM
bundling romex mazey Electrical 3 09-08-2011 08:05 PM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 02:53 PM
bundling romex, code? johnnyboy Electrical 6 10-09-2007 06:57 AM
