Bundling Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 10:04 PM   #1
Rewards Points: 1,062
bundling cable
If i bundle a 14/2, a 14/3, and a 12/3 together, representing a total of 5 circuits and 65A, to thread through the same sequence of joist holes, do you think i will be OK? I am asking because i know that more cables in a bundle means a greater fire hazard.
Old 08-27-2012, 10:06 PM   #2
Rewards Points: 164
why do you need to bundle them? just run them all through the holes seperate.....
ryan50hrl is offline   Reply With Quote
Old 08-27-2012, 10:06 PM   #3
Licensed electrician
Rewards Points: 1,238
Depending on the number of current carrying conductors through the same insulated or draft stopped hole will determine your derating factors.
Old 08-27-2012, 10:08 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
i doubt you meet the definition of bundled in my stupid opinion....
the joist are 1.5 width, you would have to be 24" continuous to be considered bundled.
The Following User Says Thank You to stickboy1375 For This Useful Post:
amakarevic (08-27-2012)
Old 08-27-2012, 10:15 PM   #5
Why would I drill 3 holes if I can drill only one? Times 25. That is 50 extra holes in your scenario.
Old 08-27-2012, 10:16 PM   #6
So in other words i am fine?
Old 08-27-2012, 10:17 PM   #7
Rewards Points: 164
yes just run them through
The Following User Says Thank You to ryan50hrl For This Useful Post:
Old 08-27-2012, 10:19 PM   #8
E2 Electrician
You are fine anyway, because you are under 9 current carrying conductors... let it fly...
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 09:15 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 09:39 AM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
