Old 05-23-2012, 10:07 AM   #1
Question
Bulldog Pushmatic "fuse"? questions
Full disclaimer in that I have essentially zero electrical repair knowledge.
I have a Bulldog Pushmatic breaker system which works fine. However, the "fuse" (or is it breaker for this set up?) won't stay in the "on" position for the air conditioner anymore. Is this something I can replace on my own or should I call on a professional?
Thanks for any advice!
Photos below:
http://www.flickr.com/photos/17622276@N00/7255679474
http://www.flickr.com/photos/17622276@N00/7255678954
juliog is offline   Reply With Quote
Old 05-23-2012, 10:35 AM   #2
Licensed electrician
Pushmatics are breakers, not fuses.
They are obsolete, but can be obtained. They screw into the bus unlike the more common push-on breakers. Installation is not too hard.
You may want to find out why the breaker will not reset. It could be a breaker issue or there might be a wiring issue.
Old 05-23-2012, 12:26 PM   #3
Breaker could very likely be doing it's job, have the A/C Checked.
Techy is offline   Reply With Quote
Old 05-23-2012, 12:31 PM   #4
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Turn off the AC disconnect or unplug it then try to turn the breaker on and if it stays on test the circuit.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-23-2012, 12:45 PM   #5
Thanks, all!
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 01:59 PM
Fake Double Pole Breaker in Pushmatic johnk88 Electrical 17 03-01-2011 11:37 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 01:36 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
