Bulhead Conceiled Electrical Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2009, 08:56 AM   #1
I'm installing a hometheater projector within an existing finished bulkhead of a room. I plan to put it in a custom wood cabinet or box without a back. I have to figure out how to get electricity to it. Is it possible to put an electrical outlet behind the projector within the bulhead that I can access when the projector is not within the "built in" cabinet? I could attach the outlet to a stud behind the cabinet within the bulkhead. There is nothing else in the bulkhead other than recessed lighting cans.
rayignacio is offline   Reply With Quote
Old 02-08-2009, 09:51 AM   #2
Remodeling Contractor
yes you can. Use a clock outlet to give a recessed receptacle outlet
Old 02-08-2009, 12:27 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
A clock outlet is OK. For a duplex Leviton also has this:
http://www.diguniverse.com/CUSTOM-IN...R42-689-W.html
They are available at any electrical distributor
For a Super Solution Leviton has full blown recessed Entertainment Boxes:
Scroll down to the Leviton 690 series that has openings for 6 Quick Port Connectors.
http://www.lashen.com/vendors/Levito..._Media/REB.asp
Quick Ports are the greatest since sliced bread:
http://www.broadbandutopia.com/levquicsnapc1.html
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-08-2009, 03:04 PM   #4
I probably did not state my question cleary... I have an enclosed, previously finished bulkhead where I will create a built in cabinet to house my projector. I need to get electricity to power the projector. I was considering putting an elecrtical outlet inside the bulkhead (not recessed), but actually in the bulkhead behind the built in housing the projector... Any issue with doing this?
Old 02-08-2009, 03:49 PM   #5
Tool Geek
PaliBob's Avatar
Can you snap a quick Pic.They are easy to upload.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-08-2009, 03:52 PM   #6
No issue with doing that. When the projector slides out, you can access the recep wiring.
220/221 is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 05:09 PM
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 09:18 PM
electrical outlet problem ? BEN17 Electrical 1 07-29-2007 07:23 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 08:59 PM
