05-14-2010, 07:00 PM
#1
Bulbs breaking in lampost
I recently moved into a house and having been having issues with the lampost outside. At first it didn't work because of a short, but was fixed by rerunning new electrical cable to the post fixture from the nearby gfci that is tapped to provide power. Now after a few months of working properly, the bulbs are physically breaking. A sizable section at the top of the bulbs is shattering. I am on the 5th bulb now and they last maybe a week. Is there a situation where a bad connection can cause bulbs to break like this? would imagine it would take a surge and at that it would cause more of the entire bulb rather than the a section of the top. The lamp fixture is rather loose on top of the post. t does not appear that the bulb can bang on aything, but I was wondering if maybe getting shaken by wind and rain while the glass is hot could the cause behind the breaking.
Any ideas or opinons?
05-14-2010, 07:13 PM
#2
Xtreme DIY'r
Where are you located ?
What type of bulb, wattage ?
Has it been raining, can water get in thru the top ?
Cold rain hitting a hot bulb will usually cause it to shatter
05-14-2010, 07:23 PM
#3
In northern west virginia, temps have been ranging over the last month from upper 30's to upper 70's at night. Yes water gets in, in fact a few times ive found water actually in what is left of the bulb. I have been thinking of trying to find something to use as a gasket for the lid and/or glass. The bulbs are the smaller A15 40 watt incandescents.
Would the suggested action be to try and tighten up the fixture and find a gasket to seal out water?
05-14-2010, 07:26 PM
#4
Xtreme DIY'r
Yup, seal out the water & that should stop it
Any water getting in could short this out & cause a shock hazard too
05-14-2010, 08:01 PM
#5
I agree. Water dripping on hot bulb is shattering it.
Do not PM with questions that can be asked in a forum. I will not respond.
05-14-2010, 09:27 PM
#6
It was a dark and stormy
I can't imagine what else it could be.
Lower wattage bulbs may be less sensitive to this type of thermal shock. The glass may not get as hot.
05-14-2010, 11:14 PM
#7
Wire Chewer
Yep sounds like water or snow. Same thing happened to my car headlight not to long ago. It's broken and I did not get it fixed yet, and we had a snow fall recently and it exploded.
I would suggest putting that circuit on GFCI as well, just to be extra safe, if it's not setup that way already.
05-15-2010, 11:50 AM
#8
Electrical Contractor
Put a CFL bulb out there, with an outer "bulb" (swirly part enclosed).
Cold water hitting it won't cause it to shatter, due to the operating temperature of the bulb.
-KB
Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
05-15-2010, 11:34 PM
#9
It is on a GFCI, there is a gfci outlet out front that its attached to. If there had not been then there could have been serious issues when the cable was shorting out when I first moved in. I'm going to take apart the housing, retighten everything so it doesnt knock around, and seal up everything with a little bit of silicon on the inside.
05-17-2010, 10:56 AM
#10
I got an idea....................................
But probably the water.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
