Bulb Wattage - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2008, 07:28 AM   #1
Rewards Points: 109
Bulb wattage
I have an outside light that says 60 watt max. If I use a 100 watt CFL bulb that only uses 23 watts is that o.k. ?
hitmehhh is offline   Reply With Quote
Old 09-21-2008, 07:37 AM   #2
electrical contractor
Rewards Points: 150
It will be fine, just make sure your cfl is marked for outdoor use or it may not light in the cold.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 09-21-2008, 07:40 AM   #3
the Musigician
DangerMouse's Avatar
the 60w limit is because of the heat created, i believe, so i think you should be fine as the cfl's are cooler in use, and use less watts.
but what do i know? listening to me has been known to cause hearing loss, genital warts, and foot fungus. check with your doctor first.
DM
Old 09-21-2008, 07:59 PM   #4
joed's Avatar
Rewards Points: 13,332
The 60 watt limit is for the actual wattage not the equivalent light wattage advertised on CFLs. The 23 watt CFL is fine for that fixture.
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 10:46 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 08:28 AM
Changing Bulb Sockets dwa Electrical 3 03-21-2008 02:30 PM
A faulty bulb or a faulty fixture? don54 Electrical 5 12-25-2007 04:38 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
