-   -   Bulb wattage (http://www.diychatroom.com/f18/bulb-wattage-27131/)
hitmehhh 09-21-2008 08:28 AM
Bulb wattage
I have an outside light that says 60 watt max. If I use a 100 watt CFL bulb that only uses 23 watts is that o.k. ?
wire_twister 09-21-2008 08:37 AM
It will be fine, just make sure your cfl is marked for outdoor use or it may not light in the cold.
DangerMouse 09-21-2008 08:40 AM
the 60w limit is because of the heat created, i believe, so i think you should be fine as the cfl's are cooler in use, and use less watts.
but what do i know? listening to me has been known to cause hearing loss, genital warts, and foot fungus. check with your doctor first.
DM
joed 09-21-2008 08:59 PM
The 60 watt limit is for the actual wattage not the equivalent light wattage advertised on CFLs. The 23 watt CFL is fine for that fixture.
