Bulb Keeps Coming Loose - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2012, 07:56 PM   #1
sweaty
Rewards Points: 270
I have a new light fixture that came with type GU24 CFL bulbs. It's the kind that has two pins and you turn it into a supposedly locked position.
Well, one of them won't lock. It keeps coming loose and turning off and the room gets too dimly lit. I have to get into the fixture and turn the bulb into place every couple weeks.
How do I fix this?
sweaty is offline   Reply With Quote
Old 03-09-2012, 08:22 PM   #2
" Euro " electrician
frenchelectrican's Avatar
How do I fix this?
Check the GU24 socket to see if there is any damage there like warped or damaged concants those two most common item I know it will affect it.
Look at your CFL bulb to make sure the base is not damaged as well.
Some case you may try differnt manufacter some case the pin may move a little that useally clear it up.
Merci,
Marc
Fire ants coming into house through pipes in foundation -- need advice samalex Pest Control 15 03-22-2011 01:35 PM
Tips for Removing GU10 Bulb? djdragan Electrical 5 12-12-2010 09:17 PM
washer and Clothes coming out of washer stink. rsplash40 Appliances 11 07-03-2009 11:05 AM
Handles for metal framed patio door coming loose abefroman General DIY Discussions 5 06-19-2009 09:54 PM
Carpet coming loose on the stairs-how to fix? imola ghost Flooring 1 09-22-2008 07:22 PM
