Bulb Keeps Burning Out - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 04:50 PM   #1
Bulb keeps burning out
I have a light above the shower that I have replaced a few times within the last year or so. It is a regular incandescent and is not over the rating for the fixture. I didn't install the fixture, but believe it is intended for use over the shower. This morning it did a high/low type strobe effect before going out. Any idea why it is burning out frequently? Thanks for the help!
tbbuhner is offline   Reply With Quote
Old 10-05-2012, 04:54 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
Check for loose connections inside the can, and at the switch.
Also check the center tab of the fixture.
Old 10-05-2012, 05:01 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,142
A good way to tell if a buld is burning for reasons other than age....look at the glass of the bulb...is the inside covered with what looks like a dark gray coating? (assuming it's not a frosted bulb).
If you see a gray coating...that is the tungston deposit on the inside of the bulb....indicating that it's a somewhat normal failure....
However, if the bulb is clear, then it indicates either a mechanical failure (cheap manuf) or bad ac connection causing excessive cycling of the filiment.
The Following User Says Thank You to ddawg16 For This Useful Post:
Blondesense (10-08-2012)
"Final" bulb in parallel circuit brighter than rest. Why? 7.62 Electrical 11 04-30-2012 05:13 PM
need help changing out light bulb gswarriorfan Electrical 13 04-17-2012 09:43 AM
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 11:46 PM
Light Bulb Burning Out GerGa Electrical 1 07-25-2011 11:20 PM
Bulbs keep burning out joelbuckley Electrical 3 11-05-2009 09:23 PM
