I have a light above the shower that I have replaced a few times within the last year or so. It is a regular incandescent and is not over the rating for the fixture. I didn't install the fixture, but believe it is intended for use over the shower. This morning it did a high/low type strobe effect before going out. Any idea why it is burning out frequently? Thanks for the help!
A good way to tell if a buld is burning for reasons other than age....look at the glass of the bulb...is the inside covered with what looks like a dark gray coating? (assuming it's not a frosted bulb).
If you see a gray coating...that is the tungston deposit on the inside of the bulb....indicating that it's a somewhat normal failure....
However, if the bulb is clear, then it indicates either a mechanical failure (cheap manuf) or bad ac connection causing excessive cycling of the filiment.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
