Built-in Mini Fridge - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2014, 01:34 PM   #1
Built-in mini fridge
Greetings! I was looking into installing a built in mini-fridge in my kitchen pantry. Power requirements are 120V 15A. My question is, can I install an outlet for it fed from an adjacent bedroom 15A AFCI? I have no other way of running power without busting up walls. I'm especially unsure of a fridge motor fed through an AFCI. Thank you.
-John
n9pbt is offline   Reply With Quote
Old 07-19-2014, 03:11 PM   #2
Rewards Points: 6,652
If it is going into a Pantry, you will find that it will die a quick death, if there is no venting for the unit. You are best to go to a Restaurant equipment reseller in your area.
AFCI's are not required as of this time for refrigeration or Kitchen Equipment. Only GFCI protection.
Old 07-19-2014, 03:33 PM   #3
That pantry is going to get might warm. You might to rethink it unless you are only storing non food items. Saw a house for sale in our once with a cooled pantry.. 55 degrees all year. I was jealous!
jimn01 is offline   Reply With Quote
Old 07-19-2014, 03:38 PM   #4
Good point about slow death. The AFCI is on the bedroom circuit that feeds an outlet I was going to tap into on a shared wall with the pantry. No power into the pantry at present. The more I'm thinking about this, the more I think it's a bad idea!
Old 07-20-2014, 01:05 AM   #5
You cannot tap off of the Bedroom circuit. The Pantry can come off of the Dining Room. But really needs to be on its own 20 amp circuit, that the Circuit Breaker needs to be a GFCI, due to by the NEC, the refer is not easily moved in your install.
Old 07-20-2014, 06:32 AM   #6
Thank you Greg for the info, I think this project is a no-go. I didn't even think about the heat in the enclosed space.
Old 07-20-2014, 10:25 AM   #7
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by gregzoll
If it is going into a Pantry, you will find that it will die a quick death, if there is no venting for the unit. You are best to go to a Restaurant equipment reseller in your area. AFCI's are not required as of this time for refrigeration or Kitchen Equipment. Only GFCI protection.
What code section?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-20-2014, 10:27 AM   #8
electures's Avatar
Greetings! I was looking into installing a built in mini-fridge in my kitchen pantry. Power requirements are 120V 15A. My question is, can I install an outlet for it fed from an adjacent bedroom 15A AFCI? I have no other way of running power without busting up walls. I'm especially unsure of a fridge motor fed through an AFCI. Thank you. -John
Is the pantry a cabinet or separate room? What is your locale?
Old 07-20-2014, 12:30 PM   #9
South Carolina, a separate room about 4' X 4'.
Old 07-20-2014, 12:35 PM   #10
electures's Avatar
Since it is a closet no gfi protection is required.
Old 07-20-2014, 12:57 PM   #11
It is now under the new NEC rules, regardless if it is a Closet.
Old 07-20-2014, 12:58 PM   #12
What code section?
You know what section. It falls under the SABC for Kitchen/Dining/Pantry.
Old 07-20-2014, 01:15 PM   #13
electures's Avatar
What code cycle are you under?
Old 07-20-2014, 04:33 PM   #14
2011 in my county.
Old 07-20-2014, 05:53 PM   #15
Master Electrician
Rewards Points: 3,876
Cite the code so we can all learn what you know.
brric is offline   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
electures (07-20-2014), stickboy1375 (07-20-2014)
Cabinet, Fridge, & Pantry fitment mystic_cobra Carpentry 8 01-17-2012 12:36 AM
Tips for Leveling Fridge unixb0y Flooring 3 09-22-2009 02:44 PM
Upright mini fridge CPERRY Appliances 1 09-08-2009 06:22 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 09:55 AM
mini fridge thermostat problems furniture_guy Appliances 1 12-19-2006 06:55 AM
