Built In Cabinet Range Hood - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2010, 11:47 AM   #1
Rewards Points: 462
Built in cabinet range hood
Hi Guys!
I don't know which subforum this topic best fits in so I'll try this one.
Some newer houses have range hoods where it is built into a cabinet. There are some of them that are tapered and look like big suction machines but I'm talking about more of a low profile unit that mounts into the underside of a cabinet, nothing fancy - just a light and exhaust.
I've found a few of these online but they are over $500.
Am I not searching the right terms to find what I'm looking for? If I could find a standard $30 range hood at the home center with the knobs on the underside I could easily hack it into a cabinet but they make all of those with the knobs on the front.
Any suggestions? Thanks
Richo is offline   Reply With Quote
Old 03-24-2010, 06:12 PM   #2
Just call me Andrew
Rewards Points: 1,020
Not sure...but you might want to try the Kitchen & Bath Remodeling Forum. I bet they'll know.
Andrew
secutanudu is offline   Reply With Quote
Old 03-24-2010, 09:33 PM   #3
firehawkmph's Avatar
Rewards Points: 1,898
Rich,
The built in hoods you mentioned usually don't come cheap. They are built with stronger fans, fancier buttons, etc. They normally end up on higher end kitchens.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-24-2010, 10:10 PM   #4
Rewards Points: 462
That's what I was starting to gather that since the only ones I could find were high end.
Looking over the one in my current kitchen I'm thinking I can probably buy a cheap one and move the controls to the underside so I can build a cabinet around it.
range hood through the wall - - -stud in the way pacifier1er Building & Construction 30 05-21-2013 09:23 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
Range Hood install opinion Manshri Appliances 5 01-01-2010 12:04 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 10:45 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
