Building Sign Troubleshooting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 07:59 PM   #1
I have a building sign that has only half of its six fluorescent light working.
I have replaced the bulbs, but still only three of the six illuminate.
Can it be a problem with the ballast? The ballast is wired in pairs of bulbs (wiring diagram HERE.) If it was the ballast, wouldn't the lights go out in pairs?
If it's not the ballast, and it's not the bulbs, does that mean the problem is in the wiring? And if so, how could the wiring have gotten screwed up after only four year in use (indoors, so I'd eliminate corrosion as a reason)?
Thanks in advance for your help.
AbelowDS is offline   Reply With Quote
Old 02-14-2012, 08:58 PM   #2
Licensed electrician
Rewards Points: 1,632
How many ballast are in the fixture? Are all the bulbs that are out off the same ballast?
Old 02-14-2012, 09:30 PM   #3
It's one ballast for all six bulbs. Allanson 648-AT.
(the wiring diagram link above brings you to a page with multiple diagrams.the one that is for this ballast is #15)
Old 02-14-2012, 09:36 PM   #4
Rewards Points: 3,256
I looked at that. Could it be multiple ballasts in one enclosure?
zappa is offline   Reply With Quote
Old 02-15-2012, 01:47 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,942
Assuming the lamps are known to be good, the problem could be the ballast or the wiring. The next troubleshooting step is to identify which lamps are out (as numbered on the wiring diagram).
mpoulton is offline   Reply With Quote
Old 02-15-2012, 06:36 AM   #6
I just opened it up... It's just the one ballast.
I'm pretty sure it's not the bulbs. I switched them all out with new bulbs and the same three fixtures lit up and the same three didn't light up.
You guys have confirmed what I thought. I'll check the wiring next. If all tests out ok, all that's left is the ballast.
Thanks so much for taking the time to respond!!
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Effect of Heat Load of Tenants on a Commercial Building mphoenix HVAC 1 04-20-2011 03:59 AM
Siding on utility building Angela3511 Building & Construction 5 04-18-2011 07:28 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
