Buck Boost Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 11:52 PM   #1
My question is if I produced 100 vac and 150 amps, out of a pma generator, could i use a transformer to switch the 100 vac to 120 vac and 150 amps to 125 amps?
Livewire78 is offline   Reply With Quote
Old 11-27-2010, 11:56 PM   #2
Rewards Points: 150
What are you trying to generate 120 with a car alternator?
Yes, it's possible. Nothing is ever 100% efficient so count on 100A @ 120V. You'll lose a little bit of power as heat, and noise from the transformer.
emolatur is offline   Reply With Quote
Old 11-28-2010, 12:09 AM   #3
Awesome, do u know where I could buy one and do they cost a lot?
Old 11-28-2010, 01:13 AM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I just have to ask: what kind of device do you have that is producing 150 amps@ 100 volts?
I didn't look at the following thoroughly but I believe they are proper.
http://temcoindustrialpower.com/prod...rs/FT2009.html
http://temcoindustrialpower.com/prod...rs/AT1475.html
http://www.powertransformer.us/buckb...ansformers.htm
here is another application chart. Didn't source the unit though.
http://www.hammondpowersolutions.com...tp-10_sec2.pdf
Old 11-28-2010, 02:11 AM   #5
Rewards Points: 150
Yeah livewire, I gotta know. Was my application guess anywhere near close?
Old 11-28-2010, 04:49 PM   #6
I found a PMA that @ 10000 rpm will produce this amount,
Old 11-28-2010, 07:49 PM   #7
nap
You talking to me?
nap's Avatar
what are you powering this with?
Old 11-28-2010, 11:33 PM   #8
Rewards Points: 150
PMA = Permanent-Magnet Alternator.
Likely a wind turbine or other homemade generating apparatus.
Old 11-28-2010, 11:44 PM   #9
nap
You talking to me?
nap's Avatar
a wind turbine to crank it at 10k rpm? That would be some serious gearing. It would also take big prop to produce that much horsepower as well.
On top of everything else, don't know if the OP realizes this but you have to convert to DC and then back to AC so you will have a constant 60 Hz. You won't get that from a wind machine. The freq varies with the wind speed.
or a very sophisticated speed regulation system
Old 11-28-2010, 11:46 PM   #10
" Euro " electrician
frenchelectrican's Avatar
At 10,000T/min that is heckva a speed is that straight DC or very high HZ ac unit ?? if that on AC side you are looking at 400 + HZ on that speed.
Merci,
Marc.
Old 11-29-2010, 09:33 AM   #11
Rewards Points: 150
Okay, a valid point, but 10K RPM after some gearing from a combustion engine is easily reasonable.
Old 11-29-2010, 10:45 AM   #12
And Still Learning
Livewire, What is your "prime mover"?
@ 10,000 rpm I hope the bearings are in perfect condition.
Know It ALL is offline   Reply With Quote
Unable to find out how to wire a dimmable light transformer Maleko Electrical 9 02-07-2010 02:07 AM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 10:44 AM
Wiring Diagram for a Transformer XR72 Electrical 7 08-12-2009 09:20 PM
Comfortmaker RPJ - Bad Transformer? olgranddad HVAC 2 12-26-2008 12:10 PM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 09:21 PM
