Bryant Parts - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2008, 09:34 PM   #1
jih
bryant parts
I am looking for Bryant electrical part - Catalog M3LB, 800 amps, 3 phase, 208 volts.
Lady in distress
jih is offline   Reply With Quote
Old 11-08-2008, 09:49 AM   #2
Rewards Points: 236
What is it? That might help.
Old 11-08-2008, 06:22 PM   #3
jih
parts
it's a buss bar in a meter box where the circut braker connects to.
Old 11-08-2008, 07:42 PM   #4
Siemans took over Bryant ages ago.
Sometines they kept using the same parts......... Not usually.
You need to contact a Siemans rep.
220/221 is offline   Reply With Quote
Old 11-09-2008, 12:00 AM   #5
I thought cutler hammer took over bryant, hence the Cutler hammer BR series. I dunno... is CH a division of siemens?
joey b is offline   Reply With Quote
Old 11-09-2008, 11:45 AM   #6
Idiot Emeritus
Rewards Points: 1,492
Any busbar work that I need to do, either add-on or replacement is usually done by a custom manufacturing shop. I make an accurate drawing of what I need, and any of the electrical supply houses around here can get it made.
It's not all that expensive, and if it's installed in a UL listed enclosure, the new piece becomes part of that listing.
Just call one of the local electrical supply houses and ask if they can get custom busbars made.
Rob
micromind is offline   Reply With Quote
Old 11-09-2008, 12:16 PM   #7
Jill, if there are no circuit breakers upstream of this bar you can have arc-flash. Maybe even with.
Cosmetic Replacement of Tub/Shower Parts MrBill_DIY Plumbing 4 06-07-2008 05:53 PM
Burner on Bryant furnace won't come on Flylowflyslow HVAC 1 09-19-2007 12:57 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 08:14 PM
can't find old replacement parts, need Air Handler coils, junkyard? sammibah HVAC 2 07-02-2006 07:43 AM
