Bryant Electrical Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2008, 10:41 AM   #1
Bryant electrical panel
Is anyone familiar with a current breaker I can buy to replace a Bryant?
Also do breakers buzz when they go bad, mine intermittently buzzes when a load is put on it? thanks guys
Teddy1731 is offline   Reply With Quote
Old 07-09-2008, 10:53 AM   #2
Licensed Pro
The BR brand of Cutler-Hammer is a listed replacement (can you guess where the BR came from?).
Old 07-09-2008, 11:46 AM   #3
Rewards Points: 82
Tighten the screw holding the wire to the breaker and see if that stops the buzzing. If not remove the breaker. Check the stab and make sure it has not gotten hot. Make sure the breaker is making good solid contact with the stab. It should take a little force to push it in. If it is easy to push in (loose) try changing the breaker first, or use another breaker in the panel to test it. If it is the panel stab and not the breaker, you probably will need to replace the panel.
Old 07-09-2008, 01:13 PM   #4
Awesome, thanks for the help guys
Old 07-29-2009, 05:15 PM   #5
RST
DIY Homeowner
Rewards Points: 150
A related question
I have a question about my Bryant panel. It has a bunch of GE breakers. Are those also permissible for use in a Bryant panel? They don't fit perfectly, but they've been in there for a long time (probably 10-25 years) with no problems (presumably).
Thanks, Robert
RST is offline   Reply With Quote
Old 07-29-2009, 06:32 PM   #6
GE's are not a match for Bryant.
I use Murray/Siemans whick are basically the same as BR's.
I did not know that. I thought Siemans was the replacement. I learnt sumpthin new today
220/221 is offline   Reply With Quote
Old 07-29-2009, 08:27 PM   #7
Household Handyman
Rewards Points: 1,408
IF any of us can keep up with "who owns who, and what brands interchange" then we are doing good nowadays. It seems like each day you find out where someone has bought out someone else, and then they sell them to someone else, etc. Why can't the government step in and make a law for universal type circuit breaker to fit all panels? DUH-never mind, stupid question as far as getting the government involved. Thanks, David
Need to change my electrical panel? 2nd opinion needed I_have_questions Electrical 60 01-30-2009 10:38 AM
How involved is it to replace the electrical panel? Alan Electrical 10 04-12-2008 11:50 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Help with electrical sub panel chrismc77 Electrical 6 08-12-2007 03:36 PM
