Broken Mule Tape - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 10:52 AM   #1
broken mule tape
i was pulling a 250 ft run when my nightmare started now i have about 125 ft of coaxl and cat5 cable in my conduit which is underground i was using mule tape my hope is i can pour something into the conduit ti disolve the mule tape so i can back the wire back outany ideas
mrmanteca is offline   Reply With Quote
Old 07-14-2011, 11:03 AM   #2
Rewards Points: 1,770
Not sure I understand (missing punctuation doesn't help). Why can't you pull it out from the end you started at and begin again?
bob22 is online now   Reply With Quote
Old 07-14-2011, 12:08 PM   #3
broken mule tape
i tried to its is jammed relly good it started breaking my cable when i tried to.
Old 07-14-2011, 12:13 PM   #4
Master Electrician
Rewards Points: 3,964
What size and type of pipe? What type and how may cables? Any "dissolvling" agent used will probably negate using the pipe further.
brric is offline   Reply With Quote
Old 07-14-2011, 12:17 PM   #5
broken mule tape
it is 1 in riged metal conduit. i have 4 pair of simese coax cable and 4 pair of cat 5 total of 8 wires
Old 07-14-2011, 12:21 PM   #6
broken mule tape
was hoping i could flush line out really good
Old 07-14-2011, 12:23 PM   #7
Rewards Points: 6,652
Actually you have 12 cables down there, which is larger than the emt. Looks like you are going to be doing some digging. Personally, I would have just pulled one coax & one cat-6, than that many.
Old 07-14-2011, 12:26 PM   #8
Master Electrician
It's not the tape that is stuck. It is a too large bundle of cabling that is stuck.
Old 07-14-2011, 12:35 PM   #9
broken mule tape
dont think bundle is to big. i could take all wires and slide the into pipe . i dont know. all i do know is tape did snap and is in pipe and i cannot pull it out from end it started from without breaking cable into.i hope if i can disolve tape i may be able to pull wire out of pipe .but i dont know what will disolve the tape
Old 07-14-2011, 12:40 PM   #10
I can't imagine a solvent that would dissolve mule tape (likely PE) without damaging the good stuff in there. Not sure if you could pump in some water/soap mixture to get it lubed a bit, pull it all out, then blow out emt to dry it and start over. Likely emt is too narrow for cables being inserted so you'll likely need fewer cables or a bigger pipe IMO.
Old 07-14-2011, 01:32 PM   #11
broken mule tape
i agree with you but clueless as to what i can use to disolve tape .i have tried plugging off line with air adapter and no success this is all bad .
Old 07-14-2011, 02:17 PM   #12
joed's Avatar
Rewards Points: 13,740
Start digging.
Old 07-14-2011, 11:09 PM   #13
Rewards Points: 50
Mule tape is made from polyester fibres. I doubt you'll find anything to dissolve it that won't cause damage to everything else. A ball of Mule Tape is actually quite slippery, however it could be snagged in the conduit. I think digging is your only option.
daveb1 is offline   Reply With Quote
Old 07-15-2011, 04:10 AM   #14
Rewards Points: 1,192
Please describe you conduit run. 1" rigid is an ideal conduit over pvc.
bobelectric is offline   Reply With Quote
Old 07-15-2011, 05:44 AM   #15
broken mule tape
it is about 237 ft is my best estimate.cant really say as i didnt put it in but i hope it only has 2 90's in it and may they be long sweeps but i dont know for sure but it is riged.im on my way back to job site to try to put air to it and try to blow it back as i pull on it .i appreciate any suggestions
Scotch Edgelock Tape: My afternoon entertainment bokeh Painting 5 06-20-2011 09:17 PM
Tape Showing cougar01 Drywall & Plaster 3 03-09-2011 04:21 PM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 06:56 PM
