Broken Light On/off Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 10:42 AM   #1
broken light on/off switch
A picture fell and broke my on/off switch (inside) for my outside sensor light. I found the pieces and glued back together, took off the cover ...switch won't fit, part seems to be sealed to get to where I need to be. How do I safely unseal or do I need to replace entire part?
KarinRomps is offline   Reply With Quote
Old 12-01-2011, 11:10 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Replace the switch for a couple of bucks.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
KarinRomps (12-01-2011), Willie T (12-01-2011)
Old 12-01-2011, 12:08 PM   #3
Thanks so much! Yes you can tell... I don't know what the hell I'm doing (or talking about!)
Is it complicated to do?
Old 12-01-2011, 12:23 PM   #4
Rewards Points: 115
hopefully you will two black wires and one bare or green wire to switch. neutrals may be spliced together in back of box. turn breaker off first. remove wires from switch and wire new switch same way.it's possible you have a switch leg going to switch. in that case you have a white and a black going to switch plus ground. wire new switch same way as that.
pokey is offline   Reply With Quote
Old 12-01-2011, 12:34 PM   #5
Hey Pokey, Thanks!! Without trying to pull it out yet... I see black, white & yellow & it's pretty dusty in there...Is that dangerous? Looks like it! Lol...
I've never done anything electrical before... just want to make sure I don't cross wires & set the dust and house on fire!!!
Old 12-01-2011, 12:35 PM   #6
joed's Avatar
Rewards Points: 13,738
Turn the power off.
Remove the swtich.
It will have two wires and maybe a ground.
Disconnect the wires and put them on the new switch.
If the switch has three wires post back. Yo have a three way switch and it needs special attention.
DO NOT CHANGE ANY OF THE OTHER WIRES IN THE SWITCH BOX.
Old 12-01-2011, 12:49 PM   #7
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
This is what I'd do. Just keep in mind I'm a blonde Polish female, and certainly no expert -so if anyone else here tells you I'm wrong, they're probably right.
1) Turn off breaker.
2) Remove cover plate and pull switch out without disconnecting anything.
3) take pictures of how everything is wired.
4) disconnect wiring.
5) take broken switch to electrical supply place. If you go to a home improvement store DON'T assume the person that is helping you knows what they are talking about.
6) reconnect according to the pics you took.
7) cross fingers and turn breaker back on.
Old 12-01-2011, 12:54 PM   #8
Hey! I see a black, white & yellow... Is that a 3 way? Thanks so much for your help! I've never looked in one of these before! Maybe I should buy a fire extinguisher with my part?!! Ok... I think I will for back up!!!
Thanks again!
Old 12-01-2011, 12:56 PM   #9
Thanks so much! Your cute!... and yes.... you pretty much said the same thing as the boys
Old 12-01-2011, 12:59 PM   #10
Stuck in the 70's
Originally Posted by KarinRomps View Post
...Maybe I should buy a fire extinguisher with my part?!! Ok... I think I will for back up!!!
Thanks again!
Definitely buy a fire extinguisher. You shouldn't need one for this, but it is a good idea to have one in the kitchen, near, but not too close to the stove.
Old 12-01-2011, 02:26 PM   #11
Old School
Willie T's Avatar
Ok, remember, if possible, you don't want to disconnect ALL the wires at once.
Hold the new switch so that it lines up the same way (in the same direction and orientation) as the old one.
TURN OFF THE BREAKER FIRST.
Take one wire off the old switch.
Now put that wire on the appropriate matching screw on the new switch.
Do the same with the next wire.
Then the next, and then the next.... if you have more wires.
Willie T
Old 12-01-2011, 04:00 PM   #12
Hey Old school Willie! Thanks for the help!
Old 12-01-2011, 04:02 PM   #13
Lol... I've been meaning to get one for a while!!! Thanks again!
Old 12-01-2011, 07:00 PM   #14
joed's Avatar
Might not work for three way switch. The common screw is not in the same place on all brands of three ways.
How many screws on the switch? Is one of them a ground (bare or green)?
Post the picture.
If it is a three way switch the important screw is the black one. That is the COMMON screw. The wire i on the COMMON screw needs to go on the common screw of the new switch. The other two wire don't matter.
The Following User Says Thank You to joed For This Useful Post:
Old 12-04-2011, 11:45 AM   #15
Rewards Points: 115
hi Karin. can you post a pic of your switch and show the terminals?
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 12:09 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
