Broken Light Fitting Or Switch. After Tripping. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 04:24 AM   #1
Broken light fitting or switch. After tripping.
After replace light globe not expecting it to be in th eon position, it shorted and tripped RCD. Reset RCD and replace globe 3 times eaach time with a different globe. Switched on and not working each time. Any suggestions either fitting or switch replacement it is also on a dimmer.
Mr Wade is offline   Reply With Quote
Old 03-23-2012, 05:09 AM   #2
Rewards Points: 3,256
It most likely fried the dimmer. With the RCD off while doing this test, take the line and load wires off of the dimmer and temporarily connect them together and see if that fixes your problem. If this doesn't work you may have permanently opened an already loose connection somewhere in the wiring between the panel and the light fixture.
zappa is offline   Reply With Quote
Wireless Light Switch? harding13 Electrical 15 12-23-2015 01:50 PM
Stopping the Light Switch from Controlling Socket theshiv Electrical 9 01-13-2012 12:12 PM
Need to add a light near switch in 3-way setup.... prosper50 Electrical 5 03-19-2011 09:19 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
