Broken Electric Feed Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 08:47 AM   #1
broken electric feed wire
Hi, I recently had some leech bed work done,while excavating they snagged the power feed to me out building. (Yeah I know, should have had area check for lines.) Anyway, its the 3 wire service supply and all 3 wires were cut. They set in soil that is always wet. Thats why they were digging in that area. How can I fix my supply lines? I would think using split bolts to peice the wire back together,but how can I keep them from getting wet? Would rubber tape work? Its about an 85 ft run and I don't want to dig it all up.
Thanks for any and all help.
Waverly Guy
waverly guy is offline   Reply With Quote
Old 06-08-2009, 08:58 AM   #2
300zx's Avatar
Post
What is the size of the wire? They make splice kits for different size wire, there is 3m. They make a Heat Shrink Repair Kit that keeps water out, You might need 6 of them
300zx is offline   Reply With Quote
Old 06-08-2009, 09:41 AM   #3
DIYer
Do you have some kind of trojan or spyware that makes you do that? Or are you just spamming?
Gigs is offline   Reply With Quote
Old 06-08-2009, 09:51 AM   #4
300zx's Avatar
Post
What are you talking about?
Old 06-08-2009, 10:28 AM   #5
DIY'r
ScottR's Avatar
ScottR is offline   Reply With Quote
Old 06-08-2009, 11:06 AM   #6
Rewards Points: 128
What size wires are you dealing with? If it were me, I would run a new feeder out there and put it in PVC conduit. Make sure you pull THWN. If the conductors are large, you can repair them. The utility repairs direct burial cable all the time.
If you do go for the repair. make absolutely sure the connection is designed for your application. WET!
Old 06-08-2009, 02:10 PM   #7
Thanks for the replies. Its #6 wire to the building service panel. It was here when I bought the house. The wiring is actually to small for the 100 amp panel, but I never use anything other than outlets and light circuit. It was put in for an RV I believe. So if I can splice it with a kit do I still need split bolts or is everything included that I would need?
Again thanks for the help.
Waverly Guy
Old 06-08-2009, 02:18 PM   #8
300zx's Avatar
Post
Everything is included.Except for the torch to shrink the kit.
Old 06-08-2009, 03:34 PM   #9
DIYer
Originally Posted by 300zx View Post
Everything is included. Except for the torch to shrink kit.
Do you realize that the words "except for the torch" are linked to some kind of weird preloaded search?
Old 06-08-2009, 04:35 PM   #10
300zx's Avatar
Post
Thanks,Didn't realize that thank you.
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
Electric Cooktop to Gas spafford Electrical 3 03-31-2008 05:43 AM
I really need help! POOK Electrical 34 04-20-2007 07:01 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 03:45 PM
