-   -   broken electric feed wire (http://www.diychatroom.com/f18/broken-electric-feed-wire-46195/)
waverly guy 06-08-2009 09:47 AM
Hi, I recently had some leech bed work done,while excavating they snagged the power feed to me out building. (Yeah I know, should have had area check for lines.) Anyway, its the 3 wire service supply and all 3 wires were cut. They set in soil that is always wet. Thats why they were digging in that area. How can I fix my supply lines? I would think using split bolts to peice the wire back together,but how can I keep them from getting wet? Would rubber tape work? Its about an 85 ft run and I don't want to dig it all up.
Thanks for any and all help.
Waverly Guy
300zx 06-08-2009 09:58 AM
What is the size of the wire? They make splice kits for different size wire, there is 3m. They make a Heat Shrink Repair Kit that keeps water out, You might need 6 of themhttp://i301.photobucket.com/albums/n...eo1/splice.jpg
Gigs 06-08-2009 10:41 AM
Do you have some kind of trojan or spyware that makes you do that? Or are you just spamming?
300zx 06-08-2009 10:51 AM
What are you talking about?
ScottR 06-08-2009 11:28 AM
:laughing::laughing:
J. V. 06-08-2009 12:06 PM
What size wires are you dealing with? If it were me, I would run a new feeder out there and put it in PVC conduit. Make sure you pull THWN. If the conductors are large, you can repair them. The utility repairs direct burial cable all the time.
If you do go for the repair. make absolutely sure the connection is designed for your application. WET!
waverly guy 06-08-2009 03:10 PM
Thanks for the replies. Its #6 wire to the building service panel. It was here when I bought the house. The wiring is actually to small for the 100 amp panel, but I never use anything other than outlets and light circuit. It was put in for an RV I believe. So if I can splice it with a kit do I still need split bolts or is everything included that I would need?
Again thanks for the help.
Waverly Guy
300zx 06-08-2009 03:18 PM
Everything is included.Except for the torch to shrink the kit.
Gigs 06-08-2009 04:34 PM
Originally Posted by 300zx (Post 284507)
Everything is included. Except for the torch to shrink kit.
Do you realize that the words "except for the torch" are linked to some kind of weird preloaded search?
300zx 06-08-2009 05:35 PM
Thanks,Didn't realize that thank you.
