Broken 120V Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 03:26 PM   #1
Broken 120V Outlets
Hi, I have two outlets on one circuit that stopped working recently. I measured the voltage and I get: 80 V between hot and neutral, 25 V between neutral and ground, 120 V between hot and ground. The ground is just a wire to the box as there are only two wires elsewhere on the circuit. The other lights and outlets are at 120 V between hot and neutral. These outlets were working a few months ago and I don't think I've made any modifications that would affect this. I'd appreciate any advice. Thanks,
Ian
ian22 is offline   Reply With Quote
Old 06-18-2011, 05:44 PM   #2
Mad Scientist
Sounds like the neutral came loose or broke somewhere. If you know which order the outlets are in on the circuit, check the first one that isn't working, and the one that's still working immediately upstream from it. Or just start opening boxes and checking connections.
If the outlets were wired with the backstab holes, it's likely that one of the connections has come loose. Re-connect them with the wires wrapped around the screw terminals, and it'll make a better and more reliable connection.
McSteve is offline   Reply With Quote
Old 06-18-2011, 05:59 PM   #3
Rewards Points: 1,760
Wire terminals as shown:
(from: http://www.reefcentral.com/forums/sh....php?t=1680545)
You don't want insulation under the screw and you don't want the wire to wrap around the screw for the full 360 degrees of the screw head.
bob22 is offline   Reply With Quote
Old 06-19-2011, 06:29 PM   #4
Yes, that was it. A previous owner made a poor connection at the junction box. Thanks for the advice!
Tags
neutral to ground voltage , outlets , wiring
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
Outlets do not work but has 120v! cosmokramer Electrical 20 01-17-2011 06:59 PM
Can I use 600v wire to connect 120v outlets Patricia54 Electrical 5 01-08-2011 03:03 PM
240v electric ranges with 120v outlets Cedar City Bob Electrical 14 09-04-2009 09:16 PM
240v appliances with 120V outlets raevenbox Electrical 21 07-02-2009 11:05 AM
