Broke Switch Off Wall For Three Way... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 12:41 PM   #1
Rewards Points: 164
Broke switch off wall for three way...
I took it apart and turned off which I thought would be the power.. but after checking with tester.. there still is pwer running to that box. I am assuming that this is do to being a three way? That being said do I have to shut off power to entire home to replace this switch or can I shut off the one and search for a secondary that would shut off all power to that switch? It is a 3 switch box 1st kitchen 2nd garage (broke one) 3rd hallway.
68MHJCs is offline   Reply With Quote
Old 01-08-2011, 12:55 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
are you using a non contact tester? if so they are unreliable. Also it is possible that two circuits are somehow tied together. but any three way should be on one breaker.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-08-2011, 12:58 PM   #3
Experienced
Jackofall1's Avatar
Turn the light on in the hallway, shut-down breakers until the light goes off, the 3-way circuit will then be de-energized.
Old 01-08-2011, 03:24 PM   #4
joed's Avatar
Rewards Points: 12,918
As long as there is not two circuits in the switch box. If there are two switches in the box there could be two circuits.
Old 01-09-2011, 08:48 AM   #5
Rewards Points: 164
Tester being used.
Greenline GT-11 Voltage Detector.
Old 01-09-2011, 10:19 AM   #6
Rewards Points: 1,514
Originally Posted by Jackofall1 View Post
Turn the light on in the hallway, shut-down breakers until the light goes off, ...
... and until all the wires in the box are dead.
Old 01-09-2011, 01:40 PM   #7
Scared Electrician
you need to use a multimeter
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 11:43 AM
Help with four way switch jwetsit Electrical 3 05-04-2010 06:05 AM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 08:13 AM
Wall Switch sue Electrical 4 02-06-2005 07:05 PM
