Broan Variable Speed Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 01:34 PM   #1
Broan variable speed motor
I have a Broan #99080349 blower motor that came from a cook top downdraft blower. It's variable speed, but I no longer have the speed controller. I'd like to use this motor in a home project, and I'd like to make it variable speed.
The cable from the motor has a normal 3-prong, 120-volt ac male connector on its end. There are no other wires going to the motor. There is a capacitor mounted on the motor, but there are no other electronics inside or outside the motor. If I plug it directly into a wall outlet, it runs at full speed. The original speed control was a very small unit consisting of a potentiometer and a few components. One of the components was a small inductor, and I think there was an SCR used also, but I can't be certain about the SCR. The specs in the manual say that the maximum ac current is 4.0 amps. So my questions are:
** What type of variable speed motor is this? I really doubt it was variable frequency, because the controller didn't seem complex enough to do such a job. The controller had no heat sink.
** Other than purchasing a new speed controller (which doesn't seem to be readily available), is there any other way to control the speed of this motor? For example, what if I used a light dimmer?
Thanks for any suggestions you can give!
geo
m0t0rgeo is offline   Reply With Quote
Old 09-22-2011, 01:58 PM   #2
Code05's Avatar
Rewards Points: 1,104
Do not use a light dimmer.
Get something like this.
http://www.iaqsource.com/product.php...product=176700
Code05 is offline   Reply With Quote
Tags
blower motor , downdraft , variable speed
variable speed trane blower motor afn63537 HVAC 25 01-13-2013 05:31 PM
Replacing HVAC blower motor with a variable speed fan bkuritz HVAC 2 06-12-2011 11:33 PM
Help Carrier, Briant Furnance with Variable motor problem ahenderson HVAC 1 12-19-2010 12:07 PM
Carrier Hi 90 Furnance variable speed motor ahenderson HVAC 0 12-18-2010 07:28 AM
variable speed motor for hvac Unregistered HVAC 2 01-14-2005 11:58 AM
