Bringing Up To Code? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 05:34 PM   #16
Licensed electrician
Rewards Points: 1,892
There are many that fear if they do not fix the issues raised by the HI that the sale will fall through. To avoid loosing the sale some will even have unnecessary work done.
What frosts me is when I refute a report as a non-issue and the homeowners go with the advise of a non-licensed person over the fear factor.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
gregzoll (08-28-2012), Speedy Petey (08-27-2012), stickboy1375 (08-27-2012)
Old 08-27-2012, 05:59 PM   #17
Rewards Points: 164
are your inspectors licensed at all by you? Maybe the licensing process is more robust here...
ryan50hrl is offline   Reply With Quote
Old 08-27-2012, 07:05 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
It helps to put your location in your profile....
With that said.....I was under the impression that unless changes are made....what ever is there....'meets code'....for when it was installed.
My house was built in 52...and has just 2 wires.....It's all in good shape....the 'only' thing that had to be changed when we bought the house in 2000, was the feed to the garage....it 'was' in the air....it had to be changed to underground conduit. Other than that, the 60A 120Vac panel stayed. Of course, that is not the situation now....
Side note regarding inspectors.....I've seen some good ones.....but it would appear that many of them are guys that couldn't make a living doing real construction work so they decided to call themselves HI's....sort of like the 'professional witness' in court rooms....
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 08-27-2012, 07:14 PM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Originally Posted by ryan50hrl View Post
Maybe thats what the inspectors around you are doing.......its not what I've witnessed here for the past 7 years......
I've seen both good and bad locally, but BY FAR many of the reports I have seen personally, the feedback I have gotten, and the first hand experience I have heard of supports my opinion.
Maybe it's you who just have a really good bunch of them? Why is that you think it is only may area that is the exception?
And to let you know, H-I's in NYS must be state licensed. The same cannot be said for many other trades.
Old 08-28-2012, 09:30 AM   #20
Originally Posted by Jim Port View Post
GFI protection marked "No Equipment Ground" or re-install two prong receptacles.
Just to confirm i picked up a gfci. Do i then find the first receptacle on the chain and replace that with the gfci and then just have to label the gfci and all the other 3 prong receptacle GFCI Protected Outlet, No Equipment Ground to be within code?
is there a limit on how many that can be labeled GFCI Protected Outlet, No Equipment Ground?
am i allowed to make my own labels if i dont have any that came with the gfci?
housemi is offline   Reply With Quote
Old 08-28-2012, 09:48 AM   #21
Rewards Points: 348
Originally Posted by stickboy1375 View Post
Personally, HI are retards.....
+100%
I had an HI come through and inspect my house before we put it on the market. In my garage, I had an old rolling microwave cart that held various car cleaning supplies. It was sitting in front of one of my panels.
He actually wrote it up that the panel was blocked and this was a violation. Did he not realize that once I moved, the cart would be going with me. It even had wheels for easy movement.
He also listed a bunch of other stuff that I fixed. When the buyer''s HI came around I had the old report and list of fixes for him. His reply was "you didn't need to fix all that". Grrrrr.
herdfan is offline   Reply With Quote
Old 08-28-2012, 06:58 PM   #22
kevinp22's Avatar
Rewards Points: 252
yes - first rec of the chain. label it no equipment ground, label the remaining gfci protected, no equipment ground
no limit unless the instructions with gfci say there is a limit
your own labels are fine. those blue ones that come with the rec are butt ugly
kevinp22 is offline   Reply With Quote
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
Plumb island sink and AAV code for Ajax jhakkim Plumbing 2 02-13-2012 11:07 PM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 10:13 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
