Bringing Up To Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 03:08 PM   #1
Bringing up to code?
i just had a house inspection. the house was built in the 1954 in the usa. it turns out a few of the 3 prong receptacles were only two wire. now this is old house 1954, what has to be done to bring it up to code since i would assume running new 12/2 with ground is not an option in most situations?
which of these options brings it up to code?
1.installing a gfci breaker and then putting a 'GFCI protected, No equipment ground sticker' on those 3 prong receptacles correct the issue of not being up to code?
2.could they just be changed back to 2 prong receptacles?
3.just put a no equipment ground label on it?
housemi is offline   Reply With Quote
Old 08-27-2012, 03:24 PM   #2
Licensed electrician
Rewards Points: 1,744
GFI protection marked "No Equipment Ground" or re-install two prong receptacles.
Old 08-27-2012, 03:38 PM   #3
That would bring me up to code then for selling the house then?
Old 08-27-2012, 03:54 PM   #4
Rewards Points: 674
Why are you concerned about bringing the house "up to code"?
B
Beepster is offline   Reply With Quote
Old 08-27-2012, 04:01 PM   #5
B
i am selling a house and the buyer is having an electrical inspection due to a few issues found from the whole house inspector (the three pong receptacles on two wire which was never caught by a whole house inspector when i brought the house). i am curious what the options are to fix the code violation.
Old 08-27-2012, 04:03 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
personally I would just reinstall 2 wire receptacles and save yourself a ton of money... let the buyer worry about it after that.
Old 08-27-2012, 04:05 PM   #7
Rewards Points: 13,960
I know if I was buying the house I would make a low ball offer knowing how much it's going to cost to up grade all the old wiring.
Old 08-27-2012, 04:14 PM   #8
E2 Electrician
You can try that... but im betting it wont get you anywhere... Its all legal wiring and nothing needs to be upgraded...
Old 08-27-2012, 04:31 PM   #9
Rewards Points: 164
Why would you do that not knowing the value of the house or what he's asking for it, a lowball offer just because something isn't done the way that is currently done isn't how it works
ryan50hrl is offline   Reply With Quote
Old 08-27-2012, 04:45 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Then the H-I did his job correctly. Their SOLE purpose is to get a lower price for the buyer.
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (08-27-2012)
Old 08-27-2012, 04:49 PM   #11
Rewards Points: 164
Not at all true.....the sole purpose of the home inspector is to ensure that both parties have the same information on the condition of the house. The home inspectors job has nothing to do with price. If I ever had a home inspector who thought it was his job to deal with the price, i would never used him again.....i've been on hundreds of home inspections......and only once ran across one inspector that thought it was his job to help the buyer negotiate.
Old 08-27-2012, 04:51 PM   #12
E2 Electrician
Personally, HI are retards.....
Old 08-27-2012, 05:00 PM   #13
Rewards Points: 164
I've found a couple that aren't bad, one I use regularly has both electrical and plumbing licenses.....and keeps up to date on stuff......
But the premise that they're there to get a lower price shouldn't be the reason to have one....
Old 08-27-2012, 05:28 PM   #14
Maybe at one time they had to do with safety and informing the buyer of potential building issues. NOT any more.
I never said they thought it was their job, it's just morphed into that. Think what you want, this is TRUE.
Old 08-27-2012, 05:32 PM   #15
Rewards Points: 164
Maybe thats what the inspectors around you are doing.......its not what I've witnessed here for the past 7 years......Are there bad apples in inspectors, electricians, brokers, mechanics, doctors....ect? Sure.....but around here the vast majority of them aren't too bad. At least around here, the prices are negotiated before the inspection, I can only think of 6 out of the past few hundred contracts i've been part of that a price reduction occurred after the inspection, almost always around here if theres an issue found the seller fixes it, or the deal falls apart.......
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
Plumb island sink and AAV code for Ajax jhakkim Plumbing 2 02-13-2012 11:07 PM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 10:13 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
