Bringing Conduit To Main Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 12:52 PM   #1
Bringing Conduit to Main Panel
Hi
I am bringing conduit into my basement from a garage sub panel. 1 1/4" PVC.
The panel is in the basement against a foundation wall, sub grade, and so it not possible to come into the back of the panel.
The lb enters the side of the house above the panel between the floor joists. There is no combination of preformed PVC that will get it to the panel. Heating and forming PVC would be a real PITA.
Is the a flexible conduit solution?
Rich
Richas is offline   Reply With Quote
Old 07-22-2012, 04:03 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Richas View Post
Hi
Rich
Liquid-Tight Flexible Nonmetallic Conduit works well, Carlon makes Carflex type brand. You could easily transition from PVC with an FA fitting.
Old 07-22-2012, 04:06 PM   #3
that's what I was hoping for! A male-male coupling glued to pvc coated flexible conduit glued to a FA fitting at the panel.
Is this correct?
Rich
Old 07-22-2012, 04:36 PM   #4
E2 Electrician
Is this correct?
Rich
Carlon does allow gluing its product to couplings, But I recommend a PVC Female adapter glued to the pvc, then just buy two car flex connectors, they come in straight or 90*, the connector will screw into the Female adapter.
Female adapter....
Carflex connector, this connector will terminate directly into a panel knockout...
Old 07-22-2012, 05:11 PM   #5
Well thanks again for the great advice. That looks like the way to go.
Cheers
Rich
Old 07-22-2012, 05:27 PM   #6
" Euro " electrician
frenchelectrican's Avatar
I have only one question is what size conductor ( wire ) you are planning to use ??
Merci,
Marc
Old 07-22-2012, 05:47 PM   #7
Merci,
Marc
Three 6 gauge and a 10 gauge ground.
Rich
Old 07-22-2012, 05:52 PM   #8
Rich
Ya will be fine with that size as long you have THHN/THWN conductors but don't use the NM cable they are not rated for underground useage and just don't try to run the big 6-3 UF cable ( it will not fit btw )
And just remember to keep the ground and netual seperated at subpanel you may need to get ground bussbar if they did not come with it and don't use the bonding screw or strap at all.
Merci,
Marc
Old 07-22-2012, 08:00 PM   #9
Merci,
Marc
Thanks Marc. I am doing all the above.
Regards
Rich
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 12:43 AM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
