Old 01-16-2012, 10:44 PM   #1
Bring romex out hole in drywall to enter junction box??
I put this at the end of another post I started but I'll ask it in its own post:
Is it wrong to bring "romex" thru a hole in drywall to enter a surface mounted j-box? Like the photo I attached. Imagine the cardboard is drywall.
Or is the proper way to use on of the back knockouts and bring the romex in via one of those?
THANKS
Minus08 is offline   Reply With Quote
Old 01-16-2012, 11:45 PM   #2
jproffer's Avatar
You can if you use the correct clamp
Just need a little bigger hole in the drywall is all
jproffer is offline   Reply With Quote
Old 01-17-2012, 12:05 AM   #3
Not sure why you would ever want to do it that way and not the right way.
Just use an old work box.
http://www.alliedmoulded.com/index.c.../categoryid/61
Old 01-17-2012, 12:35 AM   #4
WHich way are you talking about? Coming directly out of drywall like in photo where black arrow is or by using one of the rear knockouts like where the red arrow is. I know if I use a rear knockout I still need a cable clamp.
Old 01-17-2012, 12:37 AM   #5
Originally Posted by joecaption View Post
Not sure why you would ever want to do it that way and not the right way. Just use an old work box.
Not sure why? Because I want to use a surface mounted 4" square metal box like the one in the photo.
Old 01-17-2012, 12:53 AM   #6
jproffer's Avatar
Any knockout you like. It's not the best way, as Joe said...but it is compliant.
Old 01-17-2012, 01:22 AM   #7
So in your opinion it is compliant to just poke a hole in a drywall ceiling, bring the romex out of the hole and attach the romex to a surface mounted j-box.
Old 01-17-2012, 01:31 AM   #8
Julius793's Avatar
I thought we addressed it multiple time in the old thread.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-17-2012, 01:32 AM   #9
jproffer's Avatar
If it's mounted directly over the hole it's not "subject to damage", so I don't see why not. Still have to use a clamp though, but I think you mentioned above that you were planning on that.
The Following User Says Thank You to jproffer For This Useful Post:
plummen (01-17-2012)
Old 01-17-2012, 01:33 AM   #10
jproffer's Avatar
Oh...didn't see the old thread I guess.
Old 01-17-2012, 01:46 AM   #11
The question was asked as a "secondary" question in another post. I received a Yes and a No answer. So decided to ask in a topic by itself. Thats it.
Old 01-17-2012, 07:26 AM   #12
Electrical Contractor
Bring the romex right into the back of the box witout any being exsposed.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
Old 01-17-2012, 08:14 AM   #13
Licensed electrician
I think this just referred to the need for a clamp, not that you had an incorrect clamp shown.
I try to avoid the center KO so the wires do not interfer with the device being installed.
Minus08 (01-17-2012)
Old 01-17-2012, 08:20 AM   #14
jproffer's Avatar
So if there's no wire exposed outside the wall, he don't need a clamp?
It's the finer details I need to get more acquainted with.
Old 01-17-2012, 08:26 AM   #15
joed's Avatar
No matter which way you do it, you need to clamp the wire to the box.
Do not PM with questions that can be asked in a forum. I will not respond.
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 10:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Bring power to Ceiling Fan HELP mechcross Electrical 1 08-24-2008 06:45 PM
hole in drywall? econdave General Discussion 11 11-01-2007 06:29 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 11:16 AM
