Briggs Stratton Model 40320 7kw Emergency Home Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 10:53 AM   #1
briggs stratton model 40320 7kw emergency home generator
I had a briggs /stratton model 40320 emergency generator system installed yesterday and it will run for only about 20 seconds and then shut off. The installer says that he thinks the generator has a ng jet in the carb instead of the lp jet that should have been installed at the factory as this is advertised as a LP only unit. Any one else have this problem or have any suggestions?
doug preston is offline   Reply With Quote
Old 06-23-2011, 11:06 AM   #2
Master Electrician
Rewards Points: 3,678
Contact the B & S tech people to have them correct the problem. It's a new unit, under warranty. Anything someone else tries to repair could void the warranty. Also be sure there is enough gas pressure for the unit.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
doug preston (06-23-2011)
Old 06-24-2011, 12:03 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Concat the B&S service tech or someone qualifed to work on this unit and have it check out the fuel supply then check the rest of the system to make sure they are set up properly.
BTW for the generator for this size you will need half inch copper or steel pipe ( CSST may allow if your code do allow it ) and pressure for LP verison is at 11" WC or 2 PSIG depending on set up.
Merci,
Marc
Old 06-24-2011, 04:39 AM   #4
Rewards Points: 1,192
Don't sign off on the install until it's up and running. You paid a factory "Authorized" dealer.
bobelectric is offline   Reply With Quote
Old 06-24-2011, 05:59 AM   #5
Rewards Points: 77
Hope you got this fixed! I would too call the dealer back out, but also just make sure there is oil. Most units these days have oil shutoff switches.
mikeylikesit580 is offline   Reply With Quote
Old 06-24-2011, 03:35 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
This is a load of crap. That is an LP/nat convertible unit. I have installed about ten of these exact units.
It DOES NOT matter which jet was installed from the factory. It is the gas installer's responsibility to confirm that the unit is set up to run on the fuel supplied.
GFCI on generator tripping; home backup MrNeutron Electrical 21 07-02-2009 11:11 PM
Basement Flooding / Sump Pump -- Should I get a generator added to my home. DIY_Help General DIY Discussions 9 02-20-2009 06:36 PM
Computer on Generator capt2 Electrical 16 10-23-2008 11:23 AM
Briggs and Stratton Murray lawn mower issues golfer2b Landscaping & Lawn Care 3 08-01-2008 10:42 PM
Help ! May have to replace older model Streamway mobile home tub faucet valve body !! Musicloverz Plumbing 2 01-26-2008 08:04 PM
