Old 06-04-2008, 11:22 AM   #1
Breakers and Wire
I am adding a 15 Amp and a 20 Amp circuit to a panel. The 15 Amp run is about 300’ and the 20 is around 600’. I was going to use 14-2 and 12-2 respectively, but a Plunber told me that with a run that long needs 10 or 8 wire which left me scratching my head. I am running power to Baseball scoreboards and would like to use the smallest wire due to the length of the pull. (Specs on the boards call for 15 Amp & 14-2)
G3Aloha is offline   Reply With Quote
Old 06-04-2008, 11:51 AM   #2
joed's Avatar
Breakers and Wire
We need to know the actual load.
A 10 amp load at 300 feet requires #6 copper to get less than 3% drop.
A 15 amp load at 600 feet requires #2 copper to get 3% drop.
Old 06-04-2008, 07:57 PM   #3
Res Ipsa Loquitur
Breakers and Wire
If the length was 100' or less 15a and 14-2 might be an acceptable choice. The length you need causes voltage drop which requires a greater size than listed.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Arc Fault breakers (warning) Potomac101 Electrical 68 01-05-2012 04:22 PM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 11:19 PM
Circuit breakers and wire size stan 41943 Electrical 19 03-06-2008 03:29 PM
3 phase anyone? Tomkah Electrical 3 01-05-2007 06:18 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
