Breakers Defective Or Not Wired Right - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 10:08 AM   #1
gja
Question
breakers defective or not wired right
Went down the basement to label the circuits that go with each breaker. of the ten or so breakers in the panel only three had an effect and could identify which rooms they affect but the majority of breakers did nothing. So is the breaker bad or not wired right. I was hoping if the breaker was bad there would be no power in the circuit. Thank you for your help!
gja is offline   Reply With Quote
Old 10-28-2012, 10:11 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
How do you know that the breakers controlled something that is not in use anymore? Doing service changes you find, many times, breakers you cannot identify.
The Following User Says Thank You to k_buz For This Useful Post:
gja (10-28-2012)
Old 10-28-2012, 10:40 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
If you think the breaker is doing nothing, leave it turned off. You will soon find out if it is really doing nothing. Check thinks like refrigerators, freezers, sump pumps, garbage disposer, dishwasher, attic fan, OTR microwave, etc.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 10-28-2012, 10:47 AM   #4
gja
How come I could not turn off the lights by tripping the breaker.. It is like the circuit wasn't going through the panel
Old 10-28-2012, 10:50 AM   #5
k_buz's Avatar
I'm thinking you have a sub panel somewhere.
Old 10-28-2012, 03:47 PM   #6
Master Electrician
Rewards Points: 3,966
Which breaker?
brric is offline   Reply With Quote
Wiring Generator to Backfeed Breakers - Neutral and Ground Wires? tjnoff Electrical 84 12-09-2014 08:59 PM
GE Panel - Breakers - Tandem or Slim? TBrown1 Electrical 12 06-05-2012 07:42 PM
How can a buss have breakers not hot? James K Electrical 16 02-10-2012 04:14 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
