Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 03:54 PM   #1
breakers
what size breakers are needed for 1000 watts ?
k farrell is offline   Reply With Quote
Old 12-16-2010, 03:56 PM   #2
1000 watts at 120v 240v ?
1000/120 = 8.33a, 1000/240v = 4.17a
What are you wiring ?
Old 12-16-2010, 03:58 PM   #3
two 500 watt baseboards at 240v
Old 12-16-2010, 04:04 PM   #4
breakers
i have 20 amp and 15 amp single pole breakers do i have to have doubles ?
Old 12-16-2010, 05:17 PM   #5
Chewy - Lic. Electrician
Personally, as long as they are rated for it, I would run a 20amp circuit to pick up both of them on a 2 pole 20 amp breaker
SGC622 is offline   Reply With Quote
Old 12-16-2010, 05:42 PM   #6
This depends if they are 120v or 240v heaters
Old 12-16-2010, 07:18 PM   #7
Electrical Contractor
kbsparky's Avatar
A 15 Amp 2-pole breaker would be just fine for (2) 500 watt 240 Volt BB heaters.
Want to use a single pole breaker instead? It would work ... just barely. You'll only get 125 watts out of each heater that way, just slightly more heat than a 100 watt light bulb ...
-KB
Old 12-16-2010, 08:20 PM   #8
breakers
can i use two 15 amp single pole or 20 for max power ?
Old 12-16-2010, 08:22 PM   #9
jbfan's Avatar
Rewards Points: 656
Only if you use an approved handle tie, but it is easier to replace with a 2 pole breaker.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
k farrell (12-17-2010)
Old 12-16-2010, 08:49 PM   #10
I=E/R
a7ecorsair's Avatar
The breaker will not affect the heater power.
1. You will need a two pole breaker because that is how you get 240 volts out of your panel.
2. The heaters will work on either a 15 or 20 amp circuit. If you use a 15 amp two pole breaker you will use 14 awg wire. If you use a 20 amp two pole breaker you will use 12 awg wire.
What brand of panel is being used and do you know if breakers are available and easy to find?
a7ecorsair is offline   Reply With Quote
Old 12-17-2010, 10:05 AM   #11
breakers
Its a commander box and i only have single pole breakers.
I can get a double pole used but very expensive.
For the price of a 20a double i could buy a new panel.
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
Total of Circuit Breakers xraydido Electrical 19 05-13-2010 01:08 PM
Two Breakers for 1 Double Recepticle Box? mfleming Electrical 9 03-10-2010 07:28 AM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
